Edited by Exmantaa, 06 July 2011 - 07:31 AM.
How To Install A Supercharger To The Z22Se
#21
Posted 06 July 2011 - 07:25 AM
#22
(I mailed the author about this, but was never changed...)
Pin side Original: ..... ...... Switched:
D C B A ..... ...... ....... D G H A
H G F E ..... ...... ....... B C E F
The letters are written on the connector, but not everybody controls this...
Edited by Exmantaa, 06 July 2011 - 07:30 AM.
#23
Posted 29 January 2012 - 12:21 PM
#24
Posted 06 September 2012 - 02:33 PM
compliments to the precise instructions.
I want to mount the supercharger kit, can I get some information?
the supercharger kit, you've buy in U.S.A.?
could you give me the link where we can buy?
Best Regards
Matteo
#25
Posted 06 September 2012 - 02:40 PM
Non è possibile acquistare il kit è necessario acquistare la maggior parte delle parti singolarmente. Un sacco di gente compra dagli Stati Uniti.
Vi è un membro che vendeva i kit qui -
http://www.vx220.org...percharger-kit/
Ho un sovralimentato 2,2. La sua incredibile!
Scusate il mio italiano!
saluti
cristiano
Edit - È sempre possibile contattare il Forum tedesco Speedster, come hanno fatto alcune conversioni pure.
Anche in questo caso, scusate il mio italiano!
Edited by Goosenka, 06 September 2012 - 02:47 PM.
#26
Posted 06 September 2012 - 03:41 PM
Ciao
saluti
cristiano
Show off!!
#28
Posted 06 September 2012 - 03:46 PM
Invia la ECU di Courtenay Sport per la 'base map'
http://www.courtenay...s/info_206.html
Allora non sono sicuro .....
Edited by Goosenka, 06 September 2012 - 03:48 PM.
#29
Posted 06 September 2012 - 04:34 PM
Show off!!
Google translator
#30
Posted 06 September 2012 - 04:56 PM
#31
Posted 06 September 2012 - 05:11 PM
#32
Posted 06 September 2012 - 05:59 PM
#33
Posted 06 September 2012 - 06:07 PM
the Kit Kompressor is Complete?
http://shop.zzperfor...harger-Kit.aspx
http://www.courtenay...0/prod_811.html
Goosenka thanks for your time
JG: I do not understand the humor!!!!!!!!
My VX220 is yellow, the number plate is EU52ZRV, the last propietor is Handy from London
to day
#34
Posted 06 September 2012 - 06:50 PM
#35
Posted 06 September 2012 - 07:35 PM
#36
Posted 06 September 2012 - 07:50 PM
#37
Posted 06 September 2012 - 08:08 PM
Edited by Matteo21, 06 September 2012 - 08:09 PM.
#38
Posted 06 September 2012 - 08:09 PM
#39
Posted 06 September 2012 - 08:15 PM
I buy kit in U.S.A. and the remapping ECU in counternay
Matteo,
Buonasera!
I bought that ZZP kit as the basis of my SC install. Here's what you can use from it:
- Supercharger
- Inlet manifold
- Throttle body
- Throttle body bolts
- Supercharger to manifold gasket
- Charge cooler Bosch pump
- K&N air filter
- Engine breather filter
- Bolt pack
- Throttle body rewire adaptor
- Inlet manifold to head gasket
- Autolite iridium sparkplugs
- 9mm dia vacuum pipe
- Instructions sheet
Here's what you don't use:
- Idler pulley
- Charge cooler radiator
- Intake bent joiner pipe
- Intake MAF joiner tube
- Injectors
- Charge cooler pipe connector & alternator spacer pack
- Radiator hose
- MAF wiring extender
- 1807mm belt
- Oil dip stick
- 19mm charge cooler pipe (there's not enough)
- Z20LET injectors
- MAP sensor
- belt
- Idler pully bracket
- Coolant S bend
- injector plugs
- Coolant hose joiner
- 3x 41mm jubilee clips
- Courtenay base map
- Inlet support bracket
- alternator extended bolts
- EGR head cover plate
- Charge cooler header tank
- 10m of 19mm ID hose
- 5x 19mm ID 90deg elbow silicone hose
- 20x 18-32mm jubilee clips
- 5x 19mm straight connector
- 1x 19mm Y connector
Hope that helps!
Ciao.
#40
Posted 06 September 2012 - 08:26 PM
necessarily convert to lhd, because in Italy i have pay highways, and parking :-)
my last car a Ford Puma 1.7 vct 125hp, but in England there is a Ford Puma ST160, i buy in england total kit st 160 only part for engine, for update my car.
I wanted the ST160, but it is impossible to convert to LHD :-)
Also tagged with one or more of these keywords: supercharger, supercharger install, install guide, supercharger how to
General Discussion →
Tuning & Modifications →
Anyone Know Where I Can Still Get A Stage 2 M62 Supercharger Kit For ZStarted by alesaux , 11 Jul 2019 ![]() |
VX220 Discussion →
Supercharger ConversionStarted by Chrisp , 06 Dec 2015 ![]() |
Water Injection OptionsStarted by CHILL Gone DUTCH , 08 Nov 2015 ![]() |
VX220 Discussion →
Self Installation Supercharger KitStarted by Singingwolf , 07 Aug 2015 ![]() |
The Market Place →
Car Parts Wanted →
