Edited by Exmantaa, 18 September 2012 - 12:39 PM.
Posted 18 September 2012 - 12:32 PM
Posted 18 September 2012 - 01:10 PM
Posted 18 September 2012 - 01:21 PM
Very interested to join. What does it take to attend?
Edited by smiley, 18 September 2012 - 01:28 PM.
Posted 18 September 2012 - 01:35 PM
Edited by Exmantaa, 18 September 2012 - 01:37 PM.
Posted 18 September 2012 - 01:53 PM
Posted 31 October 2012 - 07:09 PM
Posted 31 October 2012 - 07:20 PM
Follow instructions not drawing and you will be okCan anyone confirm the correct wiring for the throttle plug? conflicting advice within this thread.
Cheers
Posted 01 November 2012 - 10:23 AM
Cheers
Posted 27 August 2018 - 01:56 PM
Hello,
Please, help me!
I have an Opel Vectra C 2003 with Z22SE or L61 engine. I want to convert him from naturally aspirated to supercharged. But, in my country, for cars older than ten years, we are obliged to make technical verification in every year and I think that conversion will cannot not be legalized. So, I want to make this conversion in that way that in any moment to can be revert back to initial state. I have mediu knowlige for auto mechanics and is my favorite hobby. I understand that I should purchase, the supercharger with manifold, and to make some parts relocations, but I have some other questions:
1. Why should I change my injectors, is only for connections and pipes or is for flow capacity (debit)
2. Why is need it to change the belt tensioner, it is not enough the original tensioner?
3. For cooling can I use the original engine system?
4. Is realy necessary to remap ECU?
5. Who can make the remap operation?
6. After mechanical reconversion to initial state, the remapped ECU can be used without reprogramming?
7. If the ECU itself must be revert to initial state, is it not more convinient to have a secondary spare ECU with original map on it?
8. What else modifications should be done?
9. It is really necessary to change the throttle?
Thank you!
Posted 27 August 2018 - 02:02 PM
Posted 27 August 2018 - 02:42 PM
Posted 27 August 2018 - 02:58 PM
Thank you for your answer and I know that thread is for VX220 and not for Vectra C, but I think we talk about same engine. I wish to buy parts from eBay and I want to buy from begin only what is absolutly necesary, till I'm not sure that everything will work. So:
1. For begining, if I'll keep original injectors, engine will run at a lower power or will not work at all?
2. Do you have a picture with idler puley? Where is monted?
3. For cooling manifold cannot be used same engine coolant system?
4. I saw that exist a dual pass manifold. What is the difference?
5. For begining, if I'll keep original ECU with my base map, engine will run at a lower power or will not work at all? I'm sure that I will got some errors, but I don't want to spend money on remapping and to see that does not work. Remappin procedure is not cheap.
6. Seems I will be forced to revert for few days in every year to obtain tehnical periodical inspection, I thing is more cheap to buy a secondary ECU with base map and set for my car.
7. What do you recomment, to buy a plate or a 68mm throttle?
Thank you very much!
Posted 27 August 2018 - 04:11 PM
General Discussion →
Tuning & Modifications →
Anyone Know Where I Can Still Get A Stage 2 M62 Supercharger Kit For ZStarted by alesaux , 11 Jul 2019 ![]() |
VX220 Discussion →
Supercharger ConversionStarted by Chrisp , 06 Dec 2015 ![]() |
Water Injection OptionsStarted by CHILL Gone DUTCH , 08 Nov 2015 ![]() |
VX220 Discussion →
Self Installation Supercharger KitStarted by Singingwolf , 07 Aug 2015 ![]() |
The Market Place →
Car Parts Wanted →
