It's BIG!!!!!
but quite narrow by the look of it?
Optical illusion fella, it's perfect in every proportion
can i get dibs on your old wing jimmy?
Soz dude, it's long gone.
I think Mr Jim has done a swap with somebody his for there's looking good Jimmy get that engine built
I have a nice Saab head here
Hmmmm, what work needs to be done to get it to work....? More/less work to get the standard head to work...?
Have you got adjustable cam pulleys so you can degree the cams in?
just use the saab ones much cheaper
Right can someone let me know where I can get pulleys...?
I had to machine the hub to centralise the disc so I had the camber side faces done too rather than machine the arms too
is it the brake cooling kit thats making the brake disk sit offset by a few mm, or different disks/bells
Yeah they were extra wide for some reason and I needed to machine the hub to get it to fit.
Jimmy,
Next year should be a blast! Glad you also got a proper wing too!
What's happening with your wheel arch extensions? I'm going to also have to modify my arches. I can get my car restorer chap to make me up a custom fitted set in aluminium or steel, which i guess moulds could be taken from...I'm seeing him tomorrow!
Max
Max mate keep me posted about the wheel arch extenders as mine are not looking great tbh. If you can get someone to make some nice one's I'm up for some!
