Project Jerusalem
670 replies to this topic
#421 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 18 August 2012 - 09:11 PM
So while I'm awaiting parts for the fuel system and inlet I thought I'd have a crack at my brake cooling kit and as I was chopping the liners about thought I should start to cut in my louvres properly.
Liners out
Ducting in (kinda) :)
Joe's not hte only one with a Dremmel :D
#422 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 20 August 2012 - 07:08 AM
Is it going to be ready for Saturday?
Edited by Dave E, 20 August 2012 - 07:08 AM.
#423 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 20 August 2012 - 10:56 PM
Looks cool the longer splitter I'm going to wait till I see it before I make my mind up :D
#424 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 22 August 2012 - 06:36 PM
Oh hell no :lol: :(
Too many jobs started and awaiting parts to complete. Will still be there though!!!!!
#425 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 22 August 2012 - 06:49 PM
I have one of these pics. Although the child is borrowed and i dont have a cool booster seat so she can see the road. They should make those seats for adults!
Edited by zoobeef, 22 August 2012 - 06:50 PM.
#426 The Batman
Posted 24 August 2012 - 03:16 PM
thats not the babies seat that is jjjs seat, he just happens to fit in it :lol:
#427 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 24 August 2012 - 03:24 PM
The baby will out grow it soon enough :lol:
#428 The Batman
Posted 24 August 2012 - 03:25 PM
The baby will out grow jjj soon enough :lol:
:lol:
#429 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 25 August 2012 - 09:55 PM
heeeeeeey!! wankers :D
#430 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 03 October 2012 - 06:22 PM
Ok so I'm super slow with my updates as usual :D
both front liners are long since chopped and fitted
The swirl pot tank showed up from Integrated Engineering
Very impressed by the build quality of it, very nice :)
With pump ready to fit
All torqued up with pump fitted
Check valve temproarily fitted, looks daft :D
Pump mounted in position and wired in the pump and relay. Used 2.5mm cable which should be ample!!
Trim the ties back and start adding fittings and fixtures
Now is just a case of terminating the hoses to the correct length and plumbing it all in.
#431 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 03 October 2012 - 06:32 PM
I love my hose, black hose, red hose :lol:
Then it will be a case of driving it again. Been over a year since I drove in anger now (last years Time Attack at Snetterton).
Noah's getting some driving in, but he's moved over to the BMW :lol:
Can't quite get his gear changes sorted though! :D
#432 Nev
Posted 03 October 2012 - 09:22 PM
The swirl pot looks nice and strong (thick welded sides) to me and mounting on the bulkhead behind the chassis leg and B-pillar is about as safe a place as possible. Whats the capacity of the pot once the lifter pump is in it?
#433 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 04 October 2012 - 06:06 AM
It's listed as 1.5l but I can't find if that's with or without the pump.... With I hope but that said it's listed as being good up to 650bhp so I'm sure it'll cope :)
http://www.intengine...merged-044-pump
#434 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 04 October 2012 - 07:51 AM
Looking nice Jimmy I like the swirl pot how do you get your hose so nice? I have been having problems when I cut the hose with a dremel cutter it tend to spread out and I can't get the connector on it
#435 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 04 October 2012 - 08:36 AM
I used an angle grinder so it's a much cleaner cut! You'll struggle to cut stainless braid with a dremmel mate :)
#436 Nev
Posted 04 October 2012 - 09:11 AM
The trick is to put a jubilee clip on both sides of of the pipe where you intend to cut, that way no wire splayage. :)
#437 JG
JG
  • 13,612 posts
Posted 04 October 2012 - 10:42 AM
thats what i do too. Just make sure you clean the pipe out.
Will call you this week at some stage, just been a bit manic.
#438 TazN
TazN
  • 2,931 posts
Posted 04 October 2012 - 10:56 AM
Not had liners out yet and at work so cant go check the vx myself. Does the cutout you've put in them have anything to join to the clam or is the gap fairly small and not worth the effort?
#439 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 04 October 2012 - 11:03 AM
Oooh, tha said, after reading Nev's response below I understand what you mean now.... As I said use an angle grinder but before you cut be sure to use masking tape that way the splayage is also minimised. This is how Aeroquip recommend you do it. JG posted a video somewhere showing how it's done properly :)
See above Nev, masking tape is the best method :)
************* edit, here's the vid
http://www.eaavideo....x?v=46881475001
#440 NickB787
NickB787
  • 7,813 posts
Posted 04 October 2012 - 11:57 AM
cheers guys I looked at that and thought a dremel would work ok, might try the jubilee trick
