Project Jerusalem
#501
Posted 15 November 2012 - 07:28 AM
#502
Posted 15 November 2012 - 08:29 AM
Jimmy, remind me, how did you cross the bulkhead?
There are two option in my view:
1- Enlarge the hole in the rubber grommet to take the blinded AN-6 hose. (the downside is that you end with the hose pointing in the wrong direction once in the engine bay)
2- Use a bulkhead fitting ( FBM2072 for example) across the bulkhead, with a connection either side. The upside is that there can be no chance of chafing of the hose on the bulkhead and you can use a 90 degree fitting which allows you to take the hose along the bulkhead. The downside is the introduction on 4 connection.
I went for option 1
My concern with option 2 is fitting it all in!!!
It really is a squeeze getting all this lot in and tightening it all up.
I just about managed to cram it in then pull the slack through the bulkhead. If you had fittings then it would be fixed length hoses and more AN-6 fittings to try and tighten in a more awkward place then the two above. I'm not sure it's possible......
With regards to option 1 having the hoses coming through the bulkhead it wasn't a problem as it gave the the opportunity to feed them around my swirl pot shown below (Black ended return from swirl pot and red ended supply to the bottom of the sytec filter).
#503
Posted 15 November 2012 - 08:46 AM
#504
Posted 15 November 2012 - 09:02 AM
With regards to people considering tank mounting a Bosch 044 is this an option that Pro-Alloy are offering as if not there's little chance that you'll get an 044 to fit into the original fuel pump housing. I spent ages finding my low pressure lift pump as it had to re-use the original housing so had to be identical in size.
Used one of these in the end if anybody needs one.
http://www.fuelpumps...-401-2107-p.asp
#505
Posted 15 November 2012 - 10:04 AM
I'm going to do Lee's at some point when fitting a PA tank, and go right the way back to the tank with AN lines
#506
Posted 15 November 2012 - 11:36 AM
#507
Posted 15 November 2012 - 11:42 AM
Re used the originals, but had to drill it out to a wider inner bore and then trim the outer also to get it to fit again after. Was a wrestling match if I'm honest to get it all in (as is getting the circlip back on the pump).
That is really useful and helpful.
#508
Posted 15 November 2012 - 11:44 AM
#509
Posted 15 November 2012 - 11:47 AM
#510
Posted 15 November 2012 - 11:48 AM
#511
Posted 15 November 2012 - 12:07 PM
#512
Posted 15 November 2012 - 12:43 PM
#513
Posted 15 November 2012 - 12:46 PM
#514
Posted 15 November 2012 - 05:31 PM
#515
Posted 15 November 2012 - 05:40 PM
#516
Posted 15 November 2012 - 07:18 PM
http://www.ebay.co.u...36388097&_rdc=1
These fittings are the same as the ones supplied with the Sytec filter and require PTFE tape to get a seal. My Sytec filter leaked until I contacted the seller and was advised to use PTFE. It is inert to fuel so this is safe practice.
#517
Posted 17 November 2012 - 01:52 PM
I believe the supply side fitting of the fuel rail has a 1/4" NPT thread. Means one of these takes us straight there
Not sure what thread's on the return side....
Funny you should say that:
its doesn't fit, the thread in the rail is something really odd, and there is a 45 degree metal to metal seal, but we used this at the basis for making proper ones.
#518
Posted 17 November 2012 - 04:06 PM
#519
Posted 17 November 2012 - 04:43 PM
#520
Posted 17 November 2012 - 05:47 PM
