Project Jerusalem
#541
Posted 19 November 2012 - 07:26 PM
#542
Posted 19 November 2012 - 09:41 PM
Jimmy. Please tidy your bench. Thanks.
/mum
It's a state aint it lol. That is my 'dump stuff' bench though, my work surface is on a different bench
#543
Posted 19 November 2012 - 09:59 PM
#544
Posted 19 November 2012 - 10:00 PM
#545
Posted 19 November 2012 - 10:24 PM
Car's looking fantastic Jimmy.
oh yeah and that too
#546
Posted 20 November 2012 - 02:16 PM
#547
Posted 20 November 2012 - 04:56 PM
#548
Posted 20 November 2012 - 05:48 PM
It does look great, be even better without the stickers :D/> but i suppose they are relevant to future 'plans'.
Most aren't relevant to any plans right away tbh.
Thing is It's a race car which the stickers illustrate so no need to remove them unil I get a new sticker pack my next competition (whatever that may be), Its not like indrive it to Tesco. Also in the mean time Im offering (albeit small) exposure to the people good enough to help my cause back in the day so maybe seeing this people will be more inclined to help me again in the future or new potential sponsors will see the tremendous value in sponsoring me
Plus it's alot of work removing all those!!!
#549
Posted 20 November 2012 - 06:13 PM
#550
Posted 20 November 2012 - 07:47 PM
#551
Posted 21 November 2012 - 12:16 PM
Got to leave those stickers on it's a race, race cars have livery, without them it's just a track car
#552
Posted 21 November 2012 - 12:30 PM
#553
Posted 21 November 2012 - 07:47 PM
True, my Saxo looks crap without the stickers (mainly as it's silver, we all know silver cars are ghey and invisible).
Am looking to do a bit of a makeover in the off season.
Hey Al did you see my other thread...? They've changed the towing regs again for post Jan '97
- a trailer over 750kg MAM as long as it is no more than the unladen or ‘kerb’ weight of the towing vehicle (with a combined weight of up to 3,500kg in total)
Makes life easier!!
Indeed
#554
Posted 21 November 2012 - 07:53 PM
Thing is It's a race car which the stickers illustrate so no need to remove them unil I get a new sticker pack my next competition (whatever that may be), Its not like indrive it to Tesco. Also in the mean time Im offering (albeit small) exposure to the people good enough to help my cause back in the day so maybe seeing this people will be more inclined to help me again in the future or new potential sponsors will see the tremendous value in sponsoring me :lol:/>
Plus it's alot of work removing all those!!! :D/>
Are you going in to politics Jimmy
#555
Posted 21 November 2012 - 07:55 PM
#556
Posted 21 November 2012 - 08:16 PM
#557
Posted 29 March 2013 - 09:50 AM
Jimmy, remind me, how did you cross the bulkhead?
There are two option in my view:
1- Enlarge the hole in the rubber grommet to take the blinded AN-6 hose. (the downside is that you end with the hose pointing in the wrong direction once in the engine bay)
2- Use a bulkhead fitting ( FBM2072 for example) across the bulkhead, with a connection either side. The upside is that there can be no chance of chafing of the hose on the bulkhead and you can use a 90 degree fitting which allows you to take the hose along the bulkhead. The downside is the introduction on 4 connection.
I went for option 1
My concern with option 2 is fitting it all in!!!
It really is a squeeze getting all this lot in and tightening it all up.
I just about managed to cram it in then pull the slack through the bulkhead. If you had fittings then it would be fixed length hoses and more AN-6 fittings to try and tighten in a more awkward place then the two above. I'm not sure it's possible......
With regards to option 1 having the hoses coming through the bulkhead it wasn't a problem as it gave the the opportunity to feed them around my swirl pot shown below (Black ended return from swirl pot and red ended supply to the bottom of the sytec filter).
Jimmy, do your charge cooler pipe run under the chassis?
and how did you fit the sytec filter?
#558
Posted 03 April 2013 - 11:04 AM
I've not got a heater so I use my original heater water pipes for the charge cooler (not sure of the routing of them).
The sytec filter brackets are in the pic above. I ran a small pilot drill into the extruded Ali and used self tappers.
#559
Posted 03 April 2013 - 11:35 AM
I like that... Simple and effective.
#560
Posted 03 April 2013 - 01:24 PM
