Project Jerusalem
670 replies to this topic
#581 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 28 April 2013 - 10:18 PM
OK so chipping away at getting the car ready for the National. I'm thinking the Coupe Conversion will be a winter project so got brakes and Racelogic install to sort before mapping then testing.....
So first up, ditch abs module
Tee'd using the following hoses to replace the solid lines
Calipers on with big ole discs :D
Not got the correct hoses for these yet so little more to do plumbing wise so popped the wheel on for kicks :)
So as I've got the dash off for the rev light thought I'd chuck the Vbox in and my new toys :)
Loving my cockpit these days, so OEM looking!!!!
Only thing is, with no dash and start button, this is my key to get the engine running :lol:
#582 The Batman
Posted 28 April 2013 - 10:24 PM
Wait and see maxrs dashboard You will fall in love
#583 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 28 April 2013 - 10:26 PM
Well it's off now so if you've got a lightweight alternative I want one before I put this one on :lol:
#584 Nev
Posted 28 April 2013 - 10:37 PM
Is your engine working fully without any gremlins ATM Jimmy? Interesting to see the inside of the ABS module, I have no idea how they work really.
Edited by Nev, 28 April 2013 - 10:39 PM.
#585 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 28 April 2013 - 10:44 PM
I believe so Mr C :) Was 99% sure it was a fueling issue and I've totally overhauled the system but not tested in anger yet.... Once it's back together I'll give it some stick.
Once I'm done with the brakes you're welcome to the abs module for disection thumbsup
#586 robin
robin
  • 3,810 posts
Posted 29 April 2013 - 07:15 AM
Jimmy what wires do you splice the change lights into any picture you can put up with your dash being off
#587 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 29 April 2013 - 08:23 AM
The cables going into the back of the stack....... There's one that's White with a thin black stripe. that's your tacho connection.
You just need a positive and a neutral then. I used the green connection on the stereo plug as that's an 'ignition live' so only on when key turned and the neutral I just bolted to the chassis. I used the nuts for the airbag ecu.
If you need any more info, let me know :)
#588 techieboy
Posted 29 April 2013 - 08:44 AM
Exactly the same locations I chose as well. thumbsup
#589 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 06 May 2013 - 06:14 PM
So interior is all together now and I'm quite happy how it's shaping up. Very functional!!
However, my remote button for the Vbox (bottom right in the image) doesn't work so it's al coming apart again tomorrow :beat: Hope it's the button rather than the connector on the Vbox!!!!
#590 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 06 May 2013 - 06:18 PM
What is the plan for the car Jimmy, this year and next really?
#591 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 06 May 2013 - 06:27 PM
Not sure Tim if I'm honest. I've been working on the car sporadically for the last 18 months now so I just want a few trackdays this summer to try and re-ignite my love for the car. I've got no money to race but am looking to change jobs currently so may end up with a few quid to chuck into racing again. Not sure though as I have other financial priorities these days (as I'm sure you understand :lol:).... Would love to do a OHW somewhere along the line this season (once I get the car handling right again), or would still love to hit Eurosaloons like I planned to do this year but who knows....? My future is very unclear currently!
#592 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 06 May 2013 - 06:32 PM
Dashboard looking good JJJ thumbsup
#593 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 06 May 2013 - 06:35 PM
Hi Jim, could you take some more picture of the gear linkage so I don´t have to remove my panel. :-) Looking good by the way. BR, Per
#594 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 06 May 2013 - 07:11 PM
BR, Per
Just for Per :D
#595 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 22 May 2013 - 03:08 PM
OK so a few posts back I took the plunge and ripped out the abs unit....
Since then I've been busy fitting my new caliper configuration.  Going for 4 pot AP's up front and 2 pot AP's on the rear.  I understand this is a little too much braking force on the rear of the car now but I will do some testing with different pad compounds to try and rectify this....
So....
ABS out.
New 'T' brake lines to bypass the old ABS unit.
Started plumbing into master cylinder but then after talks with our resident brake guru JohnTurbo we decided to go ahead and ditch the servo.
So, Servo out :)
Had a new plunger made for the new system
Then fitted adapter plate (also blanked off vacuum line from SC).
Then mounted master cylinder.
#596 Kieran McC
Kieran McC
  • 3,416 posts
Posted 22 May 2013 - 03:14 PM
Jimmy is this same set up as the Hoffmans Motor Sport kit ?
#597 Nev
Posted 22 May 2013 - 03:32 PM
It's a bold step to eliminate the servo, I hope you like it, the difference is startling in my experience.
Edited by Nev, 22 May 2013 - 03:33 PM.
#598 Exmantaa
Posted 22 May 2013 - 05:36 PM
:yeahthat:  Just unplug the servo vacuum hose (cap it off) and see how you like the braking now. :rolleyes:
(Best tried on an open road.)
Read somewhere that the unassisted S1 pedal leverage is different from our servo pedalbox...
Edited by Exmantaa, 22 May 2013 - 05:37 PM.
#599 Kieran McC
Kieran McC
  • 3,416 posts
Posted 22 May 2013 - 06:05 PM
Are going to run a bias valve or different pads front and rear ?
#600 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 22 May 2013 - 06:21 PM
Yes this is the Hofmann's kit.  The actual kit comes with a plunger though.
I hope so too!!  I'm changing the caliper configuration around though so the servo (I'm hoping) will not be needed.
Servo hose is still in place just capped off.  If it's no good I'll just bolt it back on :)
Was going to run the AP bias valve but it's pricey!  If I run a less grippy pad on the back I'm hoping it will balance out a bit.....
So.....  I also went about mouning the new calipers today.....
FTR brackets on the back
And with caliper and hose...
Fronts have banjo fittings so torqued up
And mounted 4 pots :)
When I stripped out the old hoses I noticed one had a rough thread so once all was properly connected I pressure tested and found a leak :(
Ordered new solid pipe (was less than a tenner)
Then ready to bleed the system through and test.  Not running with a handbrake for now, leaving cable in place however and will probably fit one of Steffan's when they're done.
ABS and Airbag alarms have been doing my head in on the dash for ages so I've linked them out so they operate as per mot rules but then drop out in normal operation :)
Big brakes in a big wheel.  Bit dirty though :)
