Posted 02 July 2013 - 10:14 AM
Posted 02 July 2013 - 10:20 AM
That's me being cheerful. I just don't do warm and cuddly, that section of my brain is irreparably damaged after too many pints and too many headbutt's. Luckily, I'm not hampered with the empathy gene in my DNA strand either. You see, I was born to be a sysadmin.I was a bit concerned Techie was cheering up a bit, particularly after the Traveller's incident, but no, pleased to see all is well
Posted 02 July 2013 - 03:09 PM
Posted 02 July 2013 - 03:23 PM
Fit the servo and disable by crimping the vacuum pipe. easily reversible.
Techie can't do the National, he is at Oulton Park crewing...
Posted 28 July 2013 - 04:33 PM
OK so those that were there saw my engine was getting a little oil surge and was breathing a littl oil into the engine bay. A little goes a long way and made a sticky horrible mess so I stripped the clam off to clean it all up.
While the clam was off I noticed the subframe mounts for my wing had been tugging on the subframe and there was a little play in them. The rear subframe is very thin with some rivnuts mounted in the top face so I decided that the subframe needed beefing up a little....
Got some plates cut from 5mm mild steel.
Cut a slot in it to take the exhaust bracket (not with the wood saw )
Drilled out pilot holes in the same layout as the original bolt pattern
Then drilled and tapped the holes with an M8 thread (6.8mm drill)
Put a couple of bolts in to test the position of the plate once butted up against the subframe. Now need to instert a retaining bolt. Didn't have any countersunk bolts left so recessed a small dome bolt. Does the trick though
Place in place with retainer bolt
Spoiler mount test bolted to subframe. Rock SOLID!
Posted 28 July 2013 - 04:42 PM
Now one for the parents out there
As mentioned previoulsy I was getting oil from my breather so needed to devise a catch tank.
Found a suitable vessle
Then got a small plastic tube to ensure the inlet is as low as possible in the bottle.
Now I thought I'd put the label back on the bottle to show where I got it from The plastic tube is a support from my sons ball pool too
Sealed the tube in the bottle with some self emalgamating tape.
Drilled a few holes and mounted inside the RH tubby ear area.
Connected up to the breather hose and job done. Happy with that
Posted 28 July 2013 - 04:43 PM
Posted 28 July 2013 - 04:47 PM
Lol. Holes look a touch small, also I think you'll melt it.
Otherwise...perfect!!
Posted 28 July 2013 - 05:19 PM
Gonna be full of water very soon
Bottle will be full in 2 track hours.
Posted 28 July 2013 - 05:52 PM
copy cat
Posted 28 July 2013 - 06:16 PM
Good luck with that. Gonna be full of water very soon
How come?
I drilled the same holes in the backside of the bottle too. Blowing through it it offers very little resistance. I wish I didn't drill three each side tbh as I wanted more air resistance.
Bottle seems quite thick, I don't think it will melt. Worth a look though
How come guys? What's the alternatve? 2 Track hours.....? That should last me a year or two ha ha
copy cat
Not seen yours so not a copy You don't even have kids anyway
Posted 28 July 2013 - 06:21 PM
Posted 28 July 2013 - 07:07 PM
The other option is not to overfill the oil
ha ha, belt and braces old boy
Posted 28 July 2013 - 07:34 PM
and i can see when its full
Posted 28 July 2013 - 08:02 PM
Christ on a bike Chris, do you mind if I delete that pic from my thread, I'd hate for anyone to think that's my car
Posted 28 July 2013 - 09:24 PM
That is a good question.
I can't tell you the exact cause. Something with over pressure generated in the cam section on our SC's, and the fact that we block off the pcv during the SC conversion (that small hole between cil 2 and 3) is making it worse.
- Some have come to piece with it, and route the rocker cover breather hose to the outside of the car.
- Vocky has extended the cam cover breather hole, and that stopped bis car blowing out oily water.
- One guy has put an extra breather in his oilcap, and that stopped bis car blowing out oily water.
- One of the belgian guys using obd tuner has created a custom gasket to enable the pcv again and that stopped bis car blowing out oily water.
- Two dutch guys quite recently put the catch tank exit back into the inlet pipe, via a T piece, on which the end has a small filter, and that stopped their cars blowing out oily water.
I will built in that last option this week, and test the solution on the zandvoort trackday end of august, to verify it also works under stress.
Edited by smiley, 28 July 2013 - 09:25 PM.
Posted 28 July 2013 - 11:24 PM
whats wrong with it?
Posted 29 July 2013 - 07:30 AM
This approach is identical to the one used by GM in the Z22SE/L61 tuning book:
It will also be the route I will be going down when I make the adaptions in a few weeks.
Posted 29 July 2013 - 12:37 PM
Yes, correct. The Belgium guy made his according the GM L61 SC conversion guide..
