Fuel Pump Replacement Guide
117 replies to this topic
#81 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 02:17 PM
when i said drill holes, i kinda meant 10mm ones.
haha, they did the job. I've dropped the fuel sender metal thing  :(
#82 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 02:23 PM
Got it, fuel evaporates damn quickly!
#83 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 02:31 PM
This is the fuel sender
Posted Image20170318_142330 by Richard Fanders, on Flickr
#84 gaffer1986
gaffer1986
  • 4,408 posts
Fitted
Posted Image20170318_142450 by Richard Fanders, on Flickr
#85 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 02:32 PM
But now the fuel pump housing won't go all the way to the bottom of the tank?
#86 smiley
Posted 18 March 2017 - 02:49 PM
Remove that black zipty that blocks the system from full compression.
And use some soapy stuff to lube the blue o-ring for easier popping.
Edited by smiley, 18 March 2017 - 02:51 PM.
#87 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 02:59 PM
Thanks smiley, I don't know what black zipty is, I realised that it's normal for it to compress so wasn't so afraid of breaking it. My hands are very sore and bleeding but it's in. I hate circlips with a passion. What's wrong with nuts and bolts.
#88 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 03:08 PM
It started first time! Hasn't started first time since I got back from cadwell! The fuel pump regulator is making a hissy sound and the pump makes a high pitch humming sound. Although I haven't put it back together yet so it may be quieter when I do that. Hopefully that sorts it :)
#89 Wolfstone
Wolfstone
  • 12,987 posts
Posted 18 March 2017 - 03:15 PM
Well done gaffer. And well done .org. thumbsup
#90 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 03:17 PM
Thanks for everyone's help. Saved me a small fortune, especially Vocky's £50 pump. Well, I haven't driven it yet so touch wood!
#91 Raptor
Raptor
  • 942 posts
Posted 18 March 2017 - 04:21 PM
result! : thumbsup
#92 vocky
Posted 18 March 2017 - 04:42 PM
I have re-added the photo links in the first post thumbsup
#93 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 04:43 PM
Thanks, yours is somewhat neater :D
#94 chris_uk
Posted 18 March 2017 - 04:44 PM
not perfectly straight which annoyed me. i will put it on the list of jobs to do lol
#95 gaffer1986
gaffer1986
  • 4,408 posts
Posted 18 March 2017 - 04:47 PM
That rubber bit is a good idea.
#96 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 March 2017 - 09:41 PM
I'm a bit worried about cutting aluminium without a vice. Do you think a plastic cover will suffice?
#97 gaffer1986
gaffer1986
  • 4,408 posts
Posted 20 March 2017 - 09:39 PM
I'm going to use plastic.
#98 gaffer1986
gaffer1986
  • 4,408 posts
Posted 20 March 2017 - 10:40 PM
  20170318_133913 by Richard Fanders, on Flickr
I'm worried that if I put plastic or aluminium over it the big black plastic thing with speakers and roof shelf won't fit too well. So I'm going to refit the inspection plate with the cut out and seal the cut line with adhesive silicone. May not be the prettiest but I'm not bothered about things you never see as long as it does the job.
#99 vocky
Posted 21 March 2017 - 08:20 AM
it does need to be quite thin to fit underneath the speaker / shelf trim
#100 quimbles
quimbles
  • 760 posts
Posted 21 March 2017 - 10:27 AM
all way neater than mine, but like you say gaffer out of sight out of mind!
i dropped a rivet in the gap between the tank, no way was i trying to fish that out..... only just after 2 years worked its way free :)
