Fuel Pump Replacement Guide
#101
Posted 21 March 2017 - 10:29 AM
#102
Posted 21 March 2017 - 10:40 AM
dunno, made its way to the road i guess, took about 5 tracks days im not sure how its all put together under there. think theres a panel with holes in it under the fuel tank.
the rivet was sliding around ontop of the fuel tank, was pretty annoying. but there was no way i was taking it all to pieces again. i blew 2 fuel pumps (loom damage) and then when i fitted the 2nd one the float got stuck on 16 litres..............
#103
Posted 21 March 2017 - 02:29 PM
I bet that was annoying, I hope my float doesn't get stuck, can't see how it could to be honest?
I've refitted the aluminium cut out, made to measure
20170321_140355 by Richard Fanders, on Flickr
The heat proof silicone sealant
20170321_141505 by Richard Fanders, on Flickr
I'll also put some duck tape around it for good measure when it's dry.
#104
Posted 21 March 2017 - 02:51 PM
you put that silicone on before refitting the round cover, right?
#105
Posted 21 March 2017 - 03:28 PM
i dont know what this is called. but the electrical measure thing the other end of the float rubs against moved up and down with the float. the plastic clip holding it in place broke off somehow.............
#106
Posted 21 March 2017 - 05:27 PM
No, the plate held it in place. The silicone is just to stop it vibrating and making noises. Plus adds a bit more strength. I think this is better than having the trim not fitting properly.you put that silicone on before refitting the round cover, right?
#107
Posted 21 March 2017 - 05:28 PM
That sucks! Well I'm sending my housing back to Vocky with a working fuel sender if you want to contact him about it.i dont know what this is called. but the electrical measure thing the other end of the float rubs against moved up and down with the float. the plastic clip holding it in place broke off somehow.............
#108
Posted 21 March 2017 - 05:50 PM
Thanks for the offer. I fixed it with a cable tie 3rd time of askingThat sucks! Well I'm sending my housing back to Vocky with a working fuel sender if you want to contact him about it.i dont know what this is called. but the electrical measure thing the other end of the float rubs against moved up and down with the float. the plastic clip holding it in place broke off somehow.............
#109
Posted 31 March 2017 - 05:36 AM
NO luck What I get is if I press the fuel cut off switch, and try starting - it fires, runs for a few seconds and cuts out. Press fuel cut off again and try - no start. So then I remove fuse to rest EML leave for 20- 30 mins and try again after pressing fuel cut off switch again - same thing runs then stops. Battery is fully charged, and it has a Battery status indicator - which is green. Any thoughts?
Hi, Im having this issue now. Can you remember what the solution was?
#110
Posted 31 March 2017 - 06:28 AM
#111
Posted 27 October 2017 - 11:20 AM
Now immortalised in PDF format on the Wikisite
wikisite fuel pump replacement guide
Anyone know if this pdf exists anywhere?
#112
Posted 28 October 2017 - 08:47 AM
That is a very ugly cutout
#113
Posted 28 October 2017 - 03:33 PM
I still have the original photos and can edit the original posts if anyone is interested, photobucket strikes again.
#114
Posted 28 October 2017 - 04:18 PM
You want to round off the corners of the hole, or the panel will fold or splay in an impact.
I found the neatest way was to use ally rivnuts and bolt an oversized plate over the hole and down the side. A bead of silicon was incase of any smell or fumes coming through.
#115
Posted 29 October 2017 - 10:06 AM
If you could Neil, that would be appreciatedI still have the original photos and can edit the original posts if anyone is interested, photobucket strikes again.
#116
Posted 29 October 2017 - 12:09 PM
photos are back
photobucket is not
#117
Posted 19 April 2018 - 01:10 PM
Hi there, I have a left hand drive VX so when you say remove passenger seat, would that men my drivers seat?
Thanks and regards,
Alistair
#118
Posted 19 April 2018 - 03:39 PM
fuel pump stays in same place for LHD cars, but you will still need to remove the passenger seat to remove the plastic bulkhead trim
