Adventure No.2
3266 replies to this topic
#181 vocky
Posted 18 February 2011 - 01:03 PM
how do you run the oil cooler with an electric water pump ?
quite easy, the electric pump outlet must feed direct to the block to avoid flow issues, so I've removed the drive sprocket and internal impellor from the factory pump (makes converting back easier - if ever required, I have also fitted the balancer delete just in case), then I had to blank off the original heater pipes (you can see the alloy blanks in the above pic).
Next job is to re-route the heater circuit, the outlet to the heater matrix comes from the engines coolant outlet (before the new remote thermostat housing), the heater return goes direct to the oil cooler and the oil cooler outlet goes into the main coolant pipe before the pump (which is where the expansion tank also connects into the coolant system).
The heater cicuit is also the thermostat bypass so the pump can still flow when the engine is cold.
Because this is a Saab engine the engine temperature sensor is mounted at the engine coolant outlet, so the original sensor was blanked off with a spare water pump drain screw (perfect fit).
The added bonus of the electric water pump is the heater actually works :D
Edited by vocky, 18 February 2011 - 01:05 PM.
#182 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 18 February 2011 - 01:05 PM
And you can leave it running when the engine is turned off thumbsup
#183 techieboy
Posted 18 February 2011 - 01:09 PM
Ding. That's the real benefit, as I see it.
#184 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 18 February 2011 - 01:15 PM
If that was combined with a totally controllable radiator fan - frigin hell that would be perfect... until the day you walk off and forget they are still running and come back to a flat battery.
#185 vocky
Posted 18 February 2011 - 01:18 PM
of course you would be best to fit the electric fan controller on the rad outlet pipe, then it's just three wires to neatly connect to the fuse box, also a good mod :closedeyes:
#186 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 18 February 2011 - 01:22 PM
Any issues of reliability with the electric pump more so than the belt driven?
#187 techieboy
Posted 18 February 2011 - 01:24 PM
Only time I'll ever say this but a role made especially for a Turbo timer.
#188 vocky
Posted 18 February 2011 - 01:29 PM
perfect for the job, might have to invest in one for mine - but only if it's light and not lardy :P
#189 vocky
Posted 18 February 2011 - 01:31 PM
10,000 hours is the life of an electric water pump, perhaps not ideal for a daily driver but perfect for a weekend toy / track car thumbsup
#190 VXT Tim
VXT Tim
  • 11,421 posts
Posted 18 February 2011 - 01:37 PM
I see thanks, I suppose I was more leaning to the 'electrical issues' some of our cars appear to suffer.
There would be no way of knowing if it'd stopped working. (that's a question really)
I'm not saying belt driven is more reliable btw. :)
#191 siztenboots
  • 26,613 posts
Posted 18 February 2011 - 01:43 PM
http://www.maplin.co...u=3315&t=module
#192 The Batman
Posted 19 February 2011 - 06:48 PM
looking good! but vocky you may have to paint that block :lol: Imnotworthy
Edited by joe_589, 19 February 2011 - 06:51 PM.
#193 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 19 February 2011 - 07:04 PM
what color.hummmmm i wonder :lol:
#194 The Batman
Posted 19 February 2011 - 07:14 PM
Silver :) or black ;) or authorcite Mmm Can't wait to drive it! Gonna have to get a couple of test trackdays in to iron out any small issues so I can be on full attack mode at the national and le mans :D Still got loads of work to do before I'm ready for a trackday though! May take a week of work to get it finished up to the point off just chucking the engine and box in!
#195 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 19 February 2011 - 07:17 PM
i like authorcite :beat: anthracite :lol:
full attack at le mans ImnotworthyImnotworthy
#196 The Batman
Posted 19 February 2011 - 07:19 PM
That's the one :lol: Le mans and I have some unfinished business! I can't wait to use the vbox and all it's glory aswell.. I heard it makes you into a racing driver as they all seem to have one :lol:
#197 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 19 February 2011 - 07:20 PM
I can be on full attack mode at le mans :D
You and me bothPosted Image
#198 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 19 February 2011 - 07:25 PM
thats why i haven't got one ;).can't afford it this years
#199 The Batman
Wanna swap cars for a few laps to see if one of us have made a bad mistake?
#200 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 19 February 2011 - 07:30 PM
Nah, saw your driving last yearPosted Image
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
