Adventure No.2
#2161
Posted 22 April 2012 - 06:55 PM
#2162
Posted 22 April 2012 - 06:58 PM
Edited by joe_589, 22 April 2012 - 06:58 PM.
#2163
Posted 22 April 2012 - 10:54 PM
It will be 99% perfect, but won't work for the water temp on the dash
Alanoo is right; it will be 98% perfect for your engine but indeed the dash water temp needs attention to work directly. Our Stack expects a PWM signal and I need to poke around in the extra ecu outputs to see if there's a suitable signal. For now you can only see ECT through an OBDII or CAN device.
The other glitch is the vehicle speed sensor signal, as the LSJ wants a 2 wire VR sinus signal (an ABS wheel sensor works perfect), but the VX deliveres a square wave to the ecu.
Both problems can probably be solved with some simple electronic components.
#2164
Posted 22 April 2012 - 11:00 PM
#2165
Posted 25 April 2012 - 03:07 PM
order some shinys from the lovely US of A!
as i have a PRO ALLOY fuel tank with proper fuel tank fixings for braided hoses, i decided to complete the circuit by fitting this to my fuel rail:
then as we are talking fuel systems might aswell show the lovely new injectors in there lovely case
So moving on, time for the intake pipe, i will be having a custom one made up (probably by a certain company
Also while i was ordering some more bits it felt a bit rude not to, to be honest.. so i bought some more cams
#2166
Posted 25 April 2012 - 03:17 PM
what cams stage are those joe?
#2167
Posted 25 April 2012 - 03:18 PM
#2168
Posted 25 April 2012 - 03:20 PM
Think mine might be with DHL. I just got a letter from them asking me for some import duty.
#2169
#2170
Posted 25 April 2012 - 03:24 PM
#2171
Posted 25 April 2012 - 03:26 PM
#2172
#2173
Posted 25 April 2012 - 03:27 PM
#2174
Edited by joe_589, 25 April 2012 - 03:28 PM.
#2175
Posted 25 April 2012 - 03:30 PM
techie i paid £50 for injectors, cams, sc oil, amm adaptor and a few pulleys
Who did yours ship with? I should probably have taken the un-insured option and got them to forward it to my Florida address, where I could have created a more realistic invoice for it.
#2176
Posted 25 April 2012 - 03:31 PM
#2177
Posted 25 April 2012 - 03:36 PM
#2178
Posted 25 April 2012 - 03:38 PM
#2179
Posted 07 May 2012 - 05:52 PM
it will also have a 12mm inlet pipe welded onto it for my cam cover breather
lightweight battery
water meth kit
Edited by joe_589, 07 May 2012 - 05:53 PM.
#2180
Posted 07 May 2012 - 06:17 PM
