Adventure No.2
3266 replies to this topic
#2201 slindborg
Posted 11 May 2012 - 09:25 PM
Epb would be better.
#2202 techieboy
No which is even more worrying :lol:
Although tomorrow is quaife Diff and new FD firing day :D oh how I love gearboxes :lol:
Deep joy. :lol:
#2203 techieboy
Seriously? I hate them with a passion.
#2204 slindborg
Posted 11 May 2012 - 09:27 PM
No, you hate the way they are controlled ;)
When done right they are the mutts nuts
#2205 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 11 May 2012 - 09:28 PM
The Jag XJR had an interesting rear setup.
Aston Martin, too. Probably the same parts bin.
Wilwood make some nice 2 and 4-pot calipers with a integrated spot caliper. It's either them or HiSpec that also make a caliper that takes an optional bolt-on spot caliper as well.
I spoke with Geary a while back about rear caliper options... The problem seemed to be focussed on a rather unsupportive bolting pattern of the hub and how willing people are to reach for their chequebook for a real solution to the problem.
#2206 techieboy
Posted 11 May 2012 - 09:33 PM
Yeah, that and the fact that Geary's rear HiSpec rear calipers with integrated handbrake mech used to bend when used. :lol: The conversion bracket is a decent solution to getting some uprated calipers on the back and there's no issue with supporting that 2-pot caliper. A spot caliper alongside that would have no additional load implications (unless you drove with it on but the pads are so small they'd disintegrate within a couple of miles).
#2207 techieboy
Bring back foot operated parking brakes I say. :lol:
#2208 slindborg
Posted 11 May 2012 - 09:43 PM
I'd sooner use my heels on the floor than anything from lospack :lol:
#2209 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 11 May 2012 - 09:47 PM
You do need that number ;)
#2210 The Batman
Posted 12 May 2012 - 06:06 PM
the vockster came round today as i decided my vx wasnt quick enough :lol:
Due to the awesomeness of the m32 to change gears and diff we didnt have to take the box off it can be done in situ Imnotworthy
sooo out come the diff and looking into the box to see some lovely vxr gears
but they where not nice enough so out come the gears and prepared the new gears. I retained the VXR 6th gear for overdrive
then decided as the diff was out might aswell fit a quaiffe!
fitted brand new OEM bearings to everything as again might aswell while its all out!
#2211 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 12 May 2012 - 06:09 PM
Not having to take the box off, wow! Id of had the fecker off then found out afterwards it was possible to do it without removing :beat: . Is it all built back up again now then?
#2212 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 12 May 2012 - 06:10 PM
What gears did you swap to?
#2213 The Batman
Posted 12 May 2012 - 06:11 PM
:lol: vocky is a master at swapping internals in the box, he did it to his about 6 million times :lol yup yup all back together even stripped the wiring harness on the engine so have loads of useless sensors and an ecu that i may set fire to :lol:
#2214 The Batman
1 - 5
kept 6th the same
#2215 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 12 May 2012 - 06:16 PM
1 - 5
kept 6th the same
From what box?
#2216 The Batman
Posted 12 May 2012 - 06:18 PM
1- 5 from a corsa vxr 6th from the astra vxr chinky chinky
#2217 JG
JG
  • 13,612 posts
Posted 12 May 2012 - 07:46 PM
that looks like good fun :) thumbsup Do you have to enlarge/regrind/clean up/do anything to the surfaces on the cast sections?
#2218 The Batman
Posted 12 May 2012 - 07:50 PM
just clean the surfaces and then resplodg'em (technical term) them back together again :)
#2219 JG
JG
  • 13,612 posts
Posted 12 May 2012 - 07:52 PM
thumbsup
#2220 CocoPops
CocoPops
  • 17,182 posts
Neil loves a bit of Splodge! :lol:
