But I made some screen shots for you.
This is how your scanner parameters should look when you have your special config set-up correctly (open the primary table window):
(If you get some "unsupported parameters" here you should connect to the ecu so it can learn the LSJ specific parameters.)
This is how it should look when you're logging a running engine. (Table window and Chart window opened):
I expect to see nothing less from you this afternoon!
Edited by Exmantaa, 28 September 2012 - 12:31 PM.
