I take it you aren't selling up then Matt?!
Doing this transplant may be the only thing that prevents me. Like JG keeps saying, it's more fun having the thing in bits than it is driving it, most of the time.
Posted 02 October 2012 - 01:36 PM
Posted 02 October 2012 - 01:39 PM
Edited by NickB777, 02 October 2012 - 01:39 PM.
Posted 02 October 2012 - 01:55 PM
Looks like I will have to replace that external trigger wheel I removed, it should do nicely for this setup, better get working on that saab head also
that 118 BTDC is the same as the z20let
Posted 02 October 2012 - 01:58 PM
I have a Saab crank in the garage. Offers please
Posted 02 October 2012 - 02:02 PM
We talked about this some ages ago:
http://www.vx220.org...60#entry1194694
Z20LET crank trigger is found to be 114* BTDC for the 1st-tooth-after-the-gap. Not so much different from the 118 degrees we measured, but the deviation here seems a bit more than a possible deviation for the trigger egde. (1 full tooth difference = 6 degrees rotation)
Posted 02 October 2012 - 02:04 PM
Posted 02 October 2012 - 04:02 PM
Was that Saab crank not moved over to your Dutch parts pile??
Posted 09 October 2012 - 11:29 AM
Posted 09 October 2012 - 11:41 AM
Posted 09 October 2012 - 11:50 AM
Posted 16 October 2012 - 08:05 PM
Posted 19 October 2012 - 07:49 AM
Posted 19 October 2012 - 09:01 AM
Posted 19 October 2012 - 09:28 AM
Edited by NickB777, 19 October 2012 - 09:29 AM.
Posted 19 October 2012 - 09:41 AM
Posted 19 October 2012 - 10:07 AM
Edited by NickB777, 19 October 2012 - 10:13 AM.
Posted 19 October 2012 - 10:19 AM
O2 SIMso he needs to fit the rear sensor back in the exhaust to see if a correct O2 signal makes the ecu happy again.
Posted 19 October 2012 - 10:20 AM
I used the cheap $200 +1mm valves, then spent another £1500 repairing the engine after one just snappeddo you know any 1mm oversized wasted stem valves which are any good( not to mention cheapish)
Uk or europe to save postage?
Edited by vocky, 19 October 2012 - 10:26 AM.
Posted 19 October 2012 - 10:50 AM
Edited by NickB777, 19 October 2012 - 10:50 AM.
Posted 19 October 2012 - 11:30 AM
Be interested to see how ther stage 2 cams go I was looking at ordering some, got to get the saab head out of the shed and start work on it. do you know any 1mm oversized wasted stem valves which are any good( not to mention cheapish)
