Adventure No.2
#241
Posted 21 April 2011 - 01:45 PM
#242
Posted 22 April 2011 - 09:19 PM
Front end:
4 pots
ARB
ARB bushes
Brake hoses
Wheel arches
Clam
Bonnet
Headlights
Front splitter
Front V
HID’s
Lightweight battery
Bolt rad surround to crash box
CC pipes
Interior:
Seats
Harness’s and harness bar
Dash plates
Door cards
Remove stereo
CC tank
Rear end:
timing chain
7L of oil
lightened crank pulley
fit intake manifold
alternator setup
coil pack
coil pack cover
wiring harness for engine bay
fill gearbox with oil
plum in eletric water pump
change rear brake discs
run cc pipes
rear brake hoses
rear clam
brake pads
bleed the hole system (clutch is done!)
bonnet
fit rear brace bar
fit hoffman spec nitrons (depending on jimmy and his finger)
add more water to the engine
fit powdercoated cam cover
EXHAUST!!!
wheel arches
fit charger
intake pipe setup
AMM
tb
air filter
water pump cc
bit of plumbing cc
ECU
spoiler
diffuser
tubby vents
jimmy was mad enough or bored enough to come and drop these round today
#243
Posted 23 April 2011 - 03:26 PM
ARB bushes
Brake hoses
Wheel arches
new front tow bracket
front brakelines
4 pots
Clam
Bonnet
Headlights
Front splitter
Front V
HID’s
Lightweight battery
CC pipes
Rear end:
7L of oil
fit intake manifold
alternator setup
coil pack
coil pack cover
run cc pipes
rear brake hoses
rear clam
brake pads
bonnet
fit rear brace bar
EXHAUST!!!
wheel arches
fit charger
intake pipe setup
AMM
tb
air filter
water pump cc
bit of plumbing cc
ECU
spoiler
splitter
diffuser
tubby vents
Interior:
Seats
Dash plates
Door cards
Remove stereo
CC tank
did a fair bit on the front end but it would appear everyone needs me today!!! unfortunately none of them had breasts
Edited by joe_589, 23 April 2011 - 03:26 PM.
#244
Posted 23 April 2011 - 03:45 PM
#245
Posted 23 April 2011 - 04:02 PM
#246
Posted 23 April 2011 - 04:06 PM
#247
Posted 23 April 2011 - 04:19 PM
#248
Posted 02 May 2011 - 12:01 PM
list of things to do:
front end:
bolt on splitter after painting
bleed brakes
headlights
battery
interior:
fit dashplates and door cards once back from the trimmer
cc tank
pax seat
fuel pump
rear:
plumb electric water pump when custom joiners arrive
get cam cover powder coated
custom intake pipe
exhaust when it arrives
cc plumbing
fit ecu
rear drivers caliper needs new dust cover for the piston
rear clam
bootlid
spoiler
tubby vents
diffusers
fuel lines
header tank
charger
bleed brakes and clutch
probably about 2 full days of work i imagine which isnt bad but as i said am missing parts which then delays other parts
Edited by joe_589, 02 May 2011 - 12:03 PM.
#249
Posted 02 May 2011 - 12:19 PM
fallen a bit out of love so lack of enthusiasm is amazing at the moment
If seeing all those working VXs yesterday dosen't inspire you, then nothing will...!
Come on Joe, get that badboy finished...(before the winter...
#250
Posted 02 May 2011 - 12:21 PM
#251
Posted 02 May 2011 - 12:27 PM
#252
Posted 02 May 2011 - 07:20 PM
#253
Posted 09 May 2011 - 02:58 PM
ducatti's big brake cooling kit:
charge cooler tank to go behind the seats:
electric water pump for the engine joiners and thermostat housing
#254
Posted 10 May 2011 - 04:27 PM
#255
Posted 10 May 2011 - 04:33 PM
#256
Posted 10 May 2011 - 04:35 PM
#257
Posted 10 May 2011 - 04:41 PM
#258
Posted 10 May 2011 - 05:05 PM
Edited by joe_589, 10 May 2011 - 05:06 PM.
#259
Posted 10 May 2011 - 06:49 PM
#260
Posted 10 May 2011 - 06:50 PM
is that a HARROP supercharger attached to that pulley
that is my wrinkly hand in the photo? i think i need to moisturise
