Adventure No.2
3266 replies to this topic
#2721 Nev
Posted 14 January 2013 - 08:57 PM
I mainly drive in the dry so need the wider wheels + greater grip that the 10"ers give me thanks.
Edited by Nev, 14 January 2013 - 09:06 PM.
#2722 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 14 January 2013 - 09:11 PM
Out of interest, what is wrong with 10" wide in the wet, and why are 9" ok in the wet?
#2723 rcvaughan
rcvaughan
    Ex-VXer
  • 3,115 posts
Posted 15 January 2013 - 03:56 AM
Did someone say Joe should fit some bigger brakes...?
:poke: :poke: :poke: :poke:
iPhone for size comparison!
#2724 The Batman
Posted 15 January 2013 - 05:14 AM
Should be with me soon :D
#2725 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 15 January 2013 - 06:44 AM
I can only imagine that it is down to spread the low weight too thinly, therefore not forcing the tyre to cut through the water and make traction.
#2726 Nev
Posted 15 January 2013 - 12:37 PM
As Mangham says it's to do with the weight/contact patch ratio. For wet conditions you generally want less contact patch to increase the pressure on the tarmac. That helps you break surface tension and get more grip. Also the larger the contact patch the harder it is to get the tyres up to working temp.
#2727 The Batman
Posted 21 January 2013 - 03:48 PM
so got a few parts in its now known as the vx220 room in my new house :rolleyes: as the shed is full up of flat pack cardboard :lol: :lol:
anyways...
full fuel system refresh, as i have the Pro Alloy 48L tank with centre collect and return, it has -8 and -6 fixings for inlet and outlet so i decided to take advatnage of these and do the full fuel system :)
then lee pestered me to be a chav at autosport :lol:
then to finish off the interior i have a set of morgan carpets, but with an extra piece to cover where the parcel shelf bit
would bePosted Image
then got a bit bored so will re design all my cc system and decided to fit this lightweight pump holder (over 1kg of weiight removed from it and that doesnt include the pump removal :lol: )
then thought why not fit a brand new cam cover, as i will be getting vocky to enlarge the breather pipe, then i will get it powder coated.
to go with the cam cover pipe i have the OEM cam cover pipe work
Edited by joe_589, 21 January 2013 - 03:49 PM.
#2728 The Batman
then onto bodywork
i have the exige rollbar reinforcing for fitting off a exige bootlid using oem hinges etc!
while we are talking about exige bootlids....
http://i586.photobuc...0ADB255666C.jpg
that should do for now....
#2729 Exmantaa
Posted 21 January 2013 - 06:23 PM
Is that a Saab oil breather hose or the US LSJ version. (looks LSJ to me) And to the fuel system; what quality fuelhose is that? And not talking about burst pressure, but is that minimal SAE 30R9 spec???
#2730 The Batman
Posted 21 January 2013 - 06:37 PM
its the lsj one :)
the whole fuel stuff was purchased from
http://stores.ebay.co.uk/Torques-U-K
can email them for you if you like?
#2731 Exmantaa
Posted 21 January 2013 - 06:48 PM
It's not my car, but would hate to see it go up in flames due to a leaking fuelhose... :ninja: And is that a special fuelfilter? Better spec than OEM??
#2732 The Batman
Posted 21 January 2013 - 06:49 PM
they are a highle recoomended company on tinterweb! making off the ends is very similar to making off armoured cable :lol: which i do thousands of a year so hopefully i wont cock it up :lol:
#2733 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 21 January 2013 - 06:55 PM
Ooooo shiney bits
#2734 CHILL Gone DUTCH
Posted 21 January 2013 - 06:56 PM
dont forget your banjo and to put a bolt and nut through it joe
#2735 The Batman
:lol:
#2736 Baron Von Scubadaddy
  • 6,644 posts
Posted 21 January 2013 - 07:02 PM
The banjo ........ worse is the sheath many a sheath sliced up the back and turned away from prying eyes !
#2737 The Batman
Posted 21 January 2013 - 07:03 PM
ah the shnood :lol: thats a proper bodge though! you disapoint me baron
#2738 CHILL Gone DUTCH
Posted 21 January 2013 - 07:05 PM
The banjo ........
worse is the sheath
I've never seen this done joe have you got a pic. Lol
#2739 The Batman
Posted 21 January 2013 - 07:06 PM
:lol: i havent actually seen it done! which is a suprise :lol: finished a job few weeks back that had to make 300 ends off :beat: very repetitive!!!
#2740 CHILL Gone DUTCH
Posted 21 January 2013 - 07:08 PM
Not as bad as data cabling
