Adventure No.2
#2921
Posted 17 August 2013 - 11:50 PM
#2922
Posted 17 August 2013 - 11:53 PM
#2923
Posted 18 August 2013 - 12:00 AM
And yes, the GT hubs are nice, but don't do anything new over the original (other than extra camber).
Well other than integrated mounts for aftermarket calipers, raised hub centres, proper mount for toe links, stronger, lighter. So not much really.
#2924
Posted 18 August 2013 - 06:50 AM
Good luck Joe, hopefully lots of hard work from you and Jimmy this weekend will get it back on the road (or close to) so you can drive it
#2925
Posted 18 August 2013 - 08:01 AM
#2926
Posted 18 August 2013 - 08:21 AM
Nice to see progress again Joe.
#2927
Posted 18 August 2013 - 08:49 AM
#2928
Posted 18 August 2013 - 10:57 AM
Don't forget to install a working post cat 2nd O2 sensor so we can properly map the LSJ ecu! You don't have a cat, right? (Maybe look for one of those cat cheater thingy's that space the senor out from the stream.)
#2929
Posted 18 August 2013 - 02:59 PM
#2930
Posted 18 August 2013 - 03:19 PM
#2931
Posted 18 August 2013 - 05:51 PM
#2932
Posted 19 August 2013 - 11:01 AM
This has always made me laugh in no way does the power of a car have any effect on the strength of the brakes.There are always these if it wasn't for the 'not for more than 200 bhp' warning: http://www.elisepart...elled-discs-s2/
Yes it could mean it would be going faster between corners but that would be a heat dissipation issue, retarding force is defined by the pads and tyres not how fast your going.
#2933
Posted 19 August 2013 - 11:22 AM
This has always made me laugh in no way does the power of a car have any effect on the strength of the brakes. Yes it could mean it would be going faster between corners but that would be a heat dissipation issue, retarding force is defined by the pads and tyres not how fast your going.
glol, tell this to scuffers. theres a thread i read recently where he's preaching about forces at maxpower through brakes...cause you know we're all pushing the throttle hard when braking...
#2934
Posted 22 August 2013 - 05:16 PM
How did the work go at the weekend? Is it close to being drivable again ?
#2935
Posted 22 August 2013 - 06:31 PM
#2936
Posted 22 August 2013 - 06:45 PM
Well done big guns.
#2937
Posted 24 August 2013 - 12:28 PM
as usual, kind of missing the point.
on a single brake event, makes no difference, over time with repeated application, more engine power = higher speeds = higher average brake loads
thus you have more heat for the disks to dissipate.
#2938
Posted 24 August 2013 - 12:47 PM
#2939
Posted 24 August 2013 - 01:16 PM
#2940
Posted 26 August 2013 - 02:26 PM
