That all depends on what you're paying for ....Did it get you a discount?Ah, ok then, I believe you. Anyway, I had a consultant paint specialist round today to give mine the once over, he said my rubbing down was exemplary.
Adventure No.2
#3081
Posted 13 October 2013 - 08:21 PM
#3082
Posted 14 October 2013 - 07:25 AM
no fog light holes , brake cooling mostly standard setup?
#3083
Posted 14 October 2013 - 12:50 PM
#3084
Posted 14 October 2013 - 07:32 PM
talking of brakes...
#3085
Posted 15 October 2013 - 08:21 PM
Happy 3rd Birthday!
#3086
Posted 15 October 2013 - 08:31 PM
#3087
Posted 15 October 2013 - 09:16 PM
#3088
Posted 15 October 2013 - 09:29 PM
#3089
Posted 15 October 2013 - 10:02 PM
#3090
Posted 16 October 2013 - 07:17 AM
Not sure how I noticed it, tbh.....!
#3091
Posted 16 December 2013 - 03:02 PM
#3092
Posted 16 December 2013 - 03:09 PM
#3093
Posted 16 December 2013 - 03:25 PM
On a more serious note; what actually still has to be done to this car, so you will be able to drive it?
#3094
Posted 16 December 2013 - 04:03 PM
#3095
Posted 16 December 2013 - 04:17 PM
#3096
Posted 16 December 2013 - 05:01 PM
Little update Managed to get hold of an eagle crank so may build another engine
Yup, I sold that to you too cheaply!
#3097
Posted 16 December 2013 - 06:38 PM
How long ago was this,Was just going to type that about checking your ZZP cams! ZZP/Comp have made a wrong batch Stage 2 cams with a too big base circle (so the valves stay slightly open) creating all sorts of bad running problems... That is very likely the cause of your bad idling and not the lack of a cat, as me and my mate both ran the LSJ ecu without a cat for quite some miles. (but do fit the 2nd Lambda sensor in the pipe!)
#3098
Posted 16 December 2013 - 07:10 PM
Probably just in time to repackage those feckers for black friday
#3099
Posted 16 December 2013 - 07:58 PM
Think 1-1.5 year ago.I think.
I bought one 2nd hand, never used set St2 and this was faulty too. Have to see how things develop cam-wide, then I can exchange these for the most suitable grind.
#3100
Posted 17 December 2013 - 08:45 AM
Is there an easy way to measure / check this?
