Adventure No.2
3266 replies to this topic
#421 chris_uk
Posted 29 June 2011 - 11:17 AM
joe ive been speaking with hi-tech aobut some ali-belled discs which are custom made for the vx, you might be interested to hear they are well cheaper than the ap stuff.
#422 siztenboots
Posted 29 June 2011 - 11:19 AM
for a good reason , cyberman had big problems with his.
#423 chris_uk
Posted 29 June 2011 - 11:22 AM
really, i ran my 330mm setup for a long time with plenty of hammer and they never were a problem. what kind of problems did he encounter?
#424 siztenboots
Posted 29 June 2011 - 11:23 AM
it was the rear brake setup that was twisting under load iirc
#425 chris_uk
Posted 29 June 2011 - 11:26 AM
i see. strange that the rears could be twisting when only 40% or so is sent that way, you would of thought the fronts would go first.
#426 techieboy
Posted 29 June 2011 - 11:31 AM
Yep, that's why Elise Parts withdrew their rear caliper (which was a rebadged HiSpec). When I spoke to HiSpec at the Autosport show 18 months ago, they reckoned they had a new version in the works. But in usual HiSpec stylee, it appears it's yet to materialise.
Still, they can't go wrong with a bell, can they........?
Just need to make sure it's got a recognised bolt pattern compatible with other rotor suppliers.
#427 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 29 June 2011 - 11:33 AM
I thought the one that Geary had on thier site was the replacement HiSpec rear caliper. I am 99% sure that he had said it was, and came about after some issues they had worked through. However it wasn't suitable for the standard upright and would require either the GT hubs or a custom mounting bracket.
#428 The Batman
Posted 29 June 2011 - 11:35 AM
not really sure what to do then? AP rotor and bells have been proven and i wouldnt want to use a make that has been withdrawn .... i have brand new 308mm drilled and grooved front with 295 drilled and grooved rears so i hopefully wont need to change for a good few months! what is the wear rate on the rotors?
#429 techieboy
Posted 29 June 2011 - 11:42 AM
Been 3 years on my AP 295's. Still not past minimum thickness (circa 15k miles and maybe 20 trackdays) but I've just changed them along with some new pads in the vain hope I can cure that nasty knocking I get on track when the brakes get hot.
#430 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 29 June 2011 - 11:47 AM
I have a 2Bular which Jim stuffed with the new wadding stuff and whilst it is noisy (98dB) it hasn't got any noisier in the 20k I have done since fitting it. Did Brands at the weekend and passed noise test there OK and din't trip off the drive by either. Just want a decat silencer now. Jim... Jim... are you there Jim... :unsure:
#431 The Batman
Posted 29 June 2011 - 11:48 AM
thats very good! i will upgrade next time i need new brakes, always wanted to do this but spent the money elsewhere on the car and the luxury discs where sacrificed :(
#432 chris_uk
Posted 29 June 2011 - 11:56 AM
my hispec rotors are about 27mm thick and started off 30mm thick, i had them of for 2 years and lad before me had them on even longer.
#433 The Batman
Posted 29 June 2011 - 11:59 AM
thats awesome good news, is this just due to the fact they are very good at dissipating heat? anyone want to buy brand new 308mm and 295mm discs drilled and grooved not been used! Imnotworthy
Edited by joe_589, 29 June 2011 - 12:00 PM.
#434 chris_uk
Posted 29 June 2011 - 12:05 PM
joe, if you are using the 17's like jimmy, i have a set of brand new 330mm alit bells and rotors..
these ones
new rotors
#435 The Batman
Posted 29 June 2011 - 12:06 PM
very kind of you and foc aswell Imnotworthy many thanks i will take them :groupjump:
#436 chris_uk
Posted 29 June 2011 - 12:07 PM
just make sure your calipers can take 30mm thick discs.
#437 The Batman
Posted 29 June 2011 - 12:12 PM
hmm lotus suggest i only use 308mm discs....
#438 chris_uk
Posted 29 June 2011 - 12:13 PM
did they say why?
#439 The Batman
Posted 29 June 2011 - 12:15 PM
just what AP spec the calipers to run :unsure: i imagine you would have to space the calipers out and they deem this as dangerous...
#440 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 29 June 2011 - 12:20 PM
these ones
new rotors
Oi, are them my discs you is offering Joe?
