vocky had a spare few minutes and popped round with a new modified water pump with a lovely machined plug to stop it ever leaking
managed to complete one side turbo vent, now to do the other one (horrible job
) tidy'd up some wiring today and also wired the guages inside (very cool lightshown start up
going to wait until i have some brass nuts (oooerrr) until i start it up again to fit the manifold to the block.
I wouldn't worry about the low revs/idleing issue too much. Mine did the same and ran like a bag of spanners under 1500 revs, simply because I had changed SO much that the old map was completely and utterly incorrect. What cam profiles have you got and did you work the head and increase valve size? In fact, can you list your full engine spec with all the parts pls?
yeah i am going to run the car again hopefully tomorrow and note down the air/fuel ratio to make sure that it is perfect or should i say SAFE! the exhaust makes a lot of bangs after releasing the throttle pedal so i imagine its over fueling quite alot? whatare your thoughts? engine spec.... hmmm here goes from memory!
b207 engine
ported and polished head
gm racing 0.5mm larger valves
supertech 78lb dual valve springs
comp blower cams
low compression z22 oversized pistons 0.20
eagle z22 rods
z22yh crank
balance delete, water pump delete, balancer chain delete
harrop
6 speed m32 vxr gearbox
full 3" 2bular with 2" primaries
porsche tb
custom air filter and pipe
pretty much sums it up i think
If you jump in the queue at CS before me I will kill you! My car has been there over a month now (waiting for a part from Klassen). Ask Jon to try and compare the engines (mine vs yours), will be interesting to hear what he thinks. Also, it would be interesting to drive each others cars to see what the driving is like as they will be first UK ones (I know of) that have genuinely exceeded 400 BHP.
im up for a swap ontrack aslong as you doesnt do wheelies
i dont know if i will break the 400bhp barrier who knows
im still not sure if i want that much... its going to ainy be a track car probably is too much! your car is completely different to mine ,you will have alot more power and torque! mine should be smoother delivery tho
It must be a such a worrying time starting the car for the first time...So well done, next Courtenays!!!!
I will also be interested in gently taking your car for a spin on track, just to see if mine could do with a Harrop being bolted on.
Yours & Nev's car will be mental...elasticated pants will be essential!
it definately was a worrying start up but it did! just gutted its not running perfect so i can take it for a drive! but i imagine its safe... so will speak to Jon tomorrow to see what he says!!
harrop is alot easier than stripping more weight and probably cheaper
