Adventure No.2
#541
Posted 17 July 2011 - 09:33 PM
#542
Posted 17 July 2011 - 09:38 PM
#543
Posted 17 July 2011 - 10:36 PM
#544
Posted 18 July 2011 - 08:41 AM
Its not always octane that dissapears from your fuel Joe. It doesn't chemically change but you'll loose the high volatiles. I'd suggest draining the tank and using it in your lawn mower or shopping trolley. Put fresh in your car.
Octane boosters are usually toluene or xylene based. 10% gunwash (mostly toluene) in your fuel gives a decent boost in octane.
and of course, never map a car with an octane booster in the tank !
#545
Posted 18 July 2011 - 09:10 AM
In fact you're unlike to lose much of the high volatility stuff as the fuel tank is a closed system, meaning it hasn't got anywhere to go.
The main cause of degradation is radical attack; metal species in the fuel will break down the fuel to shorter hydrocarbons - essentially lowering the octane number and causing more pre-ignition.
Advice is spot on though
#546
Posted 18 July 2011 - 09:35 AM
#547
Posted 18 July 2011 - 10:36 AM
#548
Posted 18 July 2011 - 10:38 AM
Joe take fuel pipe of fuel rail extend pipe to a plastic petrol can .
Then hard wire pump by taking relay of and put positive feed to pump positive job done
Put old petrol in your mums car or in the astra :-))
But do not run the pump dry at any time.
#549
Posted 18 July 2011 - 10:47 AM
#550
Posted 18 July 2011 - 11:43 AM
#551
Posted 18 July 2011 - 12:22 PM
There's no way you want an afr of 14.6 at idle. In fact, I don't think I've ever seen a car running at 14.6 at idle. Lean is better on idle, rich is better higher up in the revs.
Stage 4 Klassen/Courtenay maps idle at 14.6 precisely (+/- 0.1). I have had a wideband in my car for 3 years and it's always read that at idle. Yes, you can run leaner at idle but it's not a good idea as the turbo + manifold will overheat far faster in traffic which we all know is bad in poorly ventilated mid engined car.
#552
Posted 18 July 2011 - 12:42 PM
#553
Posted 18 July 2011 - 01:10 PM
Edited by Nev, 18 July 2011 - 01:11 PM.
#554
Posted 18 July 2011 - 01:19 PM
#555
Posted 18 July 2011 - 03:11 PM
#556
Posted 18 July 2011 - 03:12 PM
#557
Posted 18 July 2011 - 03:13 PM
After speaking to Jon at courtenays we both agreed that le mans is out the question
Boo-Hiss.
No Lee, no Fab, no Joe, no Nick.
#558
Posted 18 July 2011 - 03:14 PM
#559
Posted 18 July 2011 - 03:44 PM
bad year for the clique
Are you still coming for the social?
Sure you can grab some driver/pax laps
#560
Posted 18 July 2011 - 03:47 PM
