Adventure No.2
3266 replies to this topic
#881 MAXR
MAXR
  • 2,719 posts
Posted 10 December 2011 - 07:20 AM
Glad it's progressed Joe. It idles no worse than my car.... ...Well, do you want my opinion on how to run your car in? It's simples....
#882 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 10 December 2011 - 11:31 AM
You need different tyres before you run it in :lol:
#883 The Batman
Posted 10 December 2011 - 11:45 AM
I'm taking slindys view on running an engine in ;) Thrash it for 50 miles jobs done lol
#884 techieboy
Posted 10 December 2011 - 12:52 PM
Served me well the second time around. thumbsup
#885 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 10 December 2011 - 12:55 PM
I will swap wheels with you for some more practical winter wheels and tyres 
#886 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 10 December 2011 - 01:08 PM
I look forward to a pax young Joseph.
#887 Nev
Posted 10 December 2011 - 02:37 PM
Joe, it's not a case of thrashing it that is important (though just mild driving is not good either), I think you just need to be either accelerating or de-accelerating (rather than holding the revs steady) over a wideish range of revs. The de-acceleration is just as important as accelerating as I suspect it loads/twists the pistons/rings 180 degrees the other way to brush against the opposite side of the cylinder. I wouldn't go bokers with your revs either initially, as all your crank bearing and big end shells need to loosen up incase any of them are over-tight/pinching and not getting ample oil initially.
When I ran mine in, I was fairly progressive and started allowing boost to be generated more and more over the course of 500 miles. This seemed to work well for me. At the end of the day, the key influence in whether your engine has good compression and doesn't smoke is more to do with the quality/exactness of your rebore and relationship with the piston material and the bore/piston clearance. If I remember correctly on mine, the bore is 86.5mm and the piston rings are just 0.06 mm smaller. As yours is more of a race engine you may have reduced this bore/piston clearnce if you know you can pre-heat your engine on cold days and avoid any dreaded cold starts.
Edited by Nev, 10 December 2011 - 02:38 PM.
#888 The Batman
Posted 10 December 2011 - 02:43 PM
Nev thanks for that, although just to clarify mine isnt a race engine, merely a highly spec'd engine like yours :) and hopefully built for reliability aswell as power so very similar to your engine in that respect. I have faith in the engine, and I'm a rather big kid which kinda makes me wanna take it for a spin now but I know that fuel is crap!
#889 FLD
Posted 10 December 2011 - 03:09 PM
I agree with Nev. As long as the cams have been broken in properly dont go mad and make sure you're up and down the rev range.
#890 Nev
Posted 11 December 2011 - 11:20 AM
Yea, really watch that old fuel, syphon it off if you can. I ran my engine in initially on 1 year old fuel and it made the exhaust really noticably hotter and it ran like a dog. In retrospect I wish I had syphoned it out myself.
#891 slindborg
Posted 11 December 2011 - 11:47 AM
given the heads like to fall off the valves, I'd be wanting AFR to be in the realms of 12:1 or lower (to 9ish) under any sort of load :lol:
#892 Nev
Posted 11 December 2011 - 01:53 PM
An AFR of 9 is bloody rich just for 22 pounds of boost, maybe 10 or 10.5 would be more sensible?
#893 Exmantaa
Posted 11 December 2011 - 01:59 PM
Yes, 9-ish seems awfully rich bore washing... :dry: The big power US Ecotec guys seem to target around a safe 11.8 AFR at max torque
#894 slindborg
Posted 11 December 2011 - 02:14 PM
note the ish :P
#895 The Batman
Posted 11 December 2011 - 02:45 PM
yeah i am going to drain it to make way for my pro alloy tank :)
10-12 on the old afr is the aim then, i will make sure it stays in that :)
#896 Nev
Posted 11 December 2011 - 06:07 PM
Do you Z22 guys have a stand Bosch fitment FPR on your fuel rails ? If so, I can lend you my adjustable FPR Joe, it adjusts from 3 Bar to 5 Bar and you could set it up to over deliver fuel for the initial run in (which is what I did) for safety. Bore wash wont be a risk unless you drive a lot of miles (like 1000+) with AFRs below 9.0 Better to be safe than sorry IMO. Even better still buy a widband kit and install it - that way you can monitor your AFRs from inside the cabin as your drive.
#897 The Batman
Posted 11 December 2011 - 07:42 PM
i have a wideband fitted nev, hence the video of it :lol: you must have missed that post!!! thanks for the offer, i will go through the rev range at some point and jot all the afr's down to make sure it is safe :) it should be spot on as its nicks map and i doubt our engines differ that much. although mine will be more powerful ;)
#898 techieboy
Posted 11 December 2011 - 08:09 PM
Bitch. :lol:
#899 The Batman
Posted 11 December 2011 - 09:06 PM
:lol:
#900 Nev
Posted 11 December 2011 - 11:21 PM
Ooops, didnt see that video. Am I right in thinking you already have Nicks new map uploaded into your ECU? If so, I would have thought it was almost a perfect match and good to drive moderately hard.
