Adventure No.2
3266 replies to this topic
#1021 Exmantaa
Posted 12 January 2012 - 09:50 AM
My manifold is ported :D :lol:
It's the laminovas I have my doubt in them muchly...
I will try removing the caps in the laminover as a simple easy test but ideally j want a a new much more efficient heat exchanger
Laminova's are pretty efficient for their size and perfect for the designed job; cooling the charge in a 205HP 2.0LSJ engine in a very small space. But for higher HP/flow/heat we simply overload them.
And why do you want to remove those water caps? That will probably "shortcut" the internal waterflow and make them shed less heat...
Better do some T-measurements, as that will show you where to improve.
(And I think the bearingload of an alternative alternator is the least of your worries for a new manifold design...)
#1022 The Batman
Posted 12 January 2012 - 12:15 PM
I know Vocky was worried about the bearing load and that's why I never changed it. I was just gonna remove the caps to see what effect it has! Also to be honest even though the supercharger would be better mounted lower down I think it would be alot easier to have it in the same place Maybe flat so it makes fitting the harrop easy :lol:
#1023 The Batman
Posted 12 January 2012 - 05:11 PM
right managed to put in 2hrs work :closedeyes:
exhaust heatshield box cut and fitted
tidy up fuel tank pipes to canister
rear clam fit - interior 2 bolts and 2 nuts, sill bolts then this is done
roll bar cover
bootlid and hinges (gay na one for now)
spoiler - subframe mounts fitted and can stay on the car now, as have designed it so i dont have to take these off :D
cam cover breather - will look at various options at autosport
pax seat
re fit dash plates
fit rear diffuser
splitter
i have got another video of the AFR it seems to vary daily :blink:
AFR PARANOYA
#1024 vocky
Posted 12 January 2012 - 05:22 PM
you should refrain from running it standing still, get some miles on the engine otherwise you will get bore wash thumbsdown ps: the ecu is just learning a few parameters so it will alter with every run until you get some 'miles under the belt' - see above :poke:
#1025 The Batman
Posted 12 January 2012 - 05:26 PM
ah ok :blush: i will shut up, turn the gauge off and go for a drive rallly
#1026 Nev
Posted 12 January 2012 - 06:17 PM
I get whako readings from my AFR too Joe, even more so than you, mine can range by +-/ 1.0 from second to second. At first I thought it was due to an exhaust/manifold leak, then when I had checked that and various other things repeatedly, I came to the conclusion that it can only be to cross-flow in the head due to the inlet and exhaust cams being open at the same time. What are your cam durations and overlaps ? Also, no need to worry about running a bit lean here or there (ie +/- 2.0 ) when you are under aprox 8 psi of boost IMO. I ran my engine in like this for 750 miles without any probs. It's ever to easy to get super cautious I know, just go for a sensible drive and flex the revs up and down without getting any serious boost if I were you.
Edited by Nev, 12 January 2012 - 06:19 PM.
#1027 Exmantaa
Posted 12 January 2012 - 07:18 PM
Nothing wrong with those AFR readings. In standstill you're not giving any load to the engine so it (should) runs in closed loop with a fluctuating AFR around 14.7. You see it richens up on throttle and then goes very lean on coast down when the injectors are shut off. That's pretty normal, so leave it, finish the remaining points and start driving it to properly load up the pistonrings. :sleep:
#1028 The Batman
Posted 12 January 2012 - 07:20 PM
ok i will get it sorted and note done so load AFRs techieboy do not buy an AFR guage :lol: just got some bits to make a custom brace bar :D
#1029 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 12 January 2012 - 07:34 PM
Here's a picture of one I did earlier :) Since the photo it's got a beefier centre adjuster and it's been powder coated but it's basically the same.
#1030 The Batman
Posted 12 January 2012 - 07:36 PM
Does it need to be adjustable? I was going to make one without an adjuster,..
#1031 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 12 January 2012 - 07:43 PM
Not really, can't remember why we did it now tbh, suppose it easier to make as the measurements aren't as critical.
#1032 The Batman
Posted 12 January 2012 - 07:46 PM
ah i see :lol: will probably make mine tomorrow hopefully (after autosport and before work (no sleep for the wicked eh?)
#1033 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 12 January 2012 - 07:50 PM
Working Friday night :o you must be planning on spending large at the show
#1034 The Batman
Posted 12 January 2012 - 07:51 PM
i know i know.. shocking isnt it. i am working next weekend aswell and probably the one after that :( to be honest i dont have much to buy tomorrow.. going to look at various cam cover breather methods, some race boots/gloves and thats about it really! are you going tomorrow? if so what you going to look for? i need inspiration :D
#1035 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 12 January 2012 - 07:53 PM
I'll be there, I'm going to be looking for a deal on a couple of items to finish my latest project :)
#1036 slindborg
Posted 12 January 2012 - 08:35 PM
Afr will be sh** as the ecu won't go into closed loop till the engine is warm enough...... Longer than your mincing about.
#1037 The Batman
Posted 12 January 2012 - 08:59 PM
Ecus are crap :lol:
#1038 slindborg
Posted 12 January 2012 - 09:04 PM
Ecus are crap :lol:
Carbs and dizzies are worse
#1039 The Batman
Posted 13 January 2012 - 04:04 AM
anyways had some steel conduit laying around so i decided to make my brace bar there are 2 spare holes in the subframes next to where the toe links bolt into so i will bolt through those existing holes. anyways as i have a 3" exhaust system and the fact i want to use these existing holes means i cannot use just a straight bar so i borrowed a bender (oooerrr) :lol: from work and made it into a prototype bracebar! i left it in the van and havent taken a photo yet :lol: so i will update with photos tomorrow oh and the main thing of whether it fits and avoids the exhaust which im sure it will :D a basic shape is ''''________/'''' then i crushed using a vice both ends to make them flat'ish. as its rather late i havent drilled the holes yet but i have them lined up, so i will drill the holes m8 as i used 20mm conduit. i will bolt it so that a nut fits inside the conduit and then crush it more so that i is SOLID! anyways this post is crap without photos so will update tomorrow (just wish i never fitted my rear diiffuser yesterday :beat: as its a pig to fit!) chinky chinky
#1040 JG
JG
  • 13,612 posts
Posted 13 January 2012 - 06:32 AM
photos please. also need to get your ideas on cam cover breather at the show. mine is a bit heath robinson.
