Adventure No.2
3266 replies to this topic
#1221 The Batman
Posted 19 January 2012 - 11:53 AM
yup :)
#1222 chris_uk
Posted 19 January 2012 - 11:55 AM
If he doesnt ( but i think he does) i do so yea, thats covered. Only problem is monitoring it as the scangauge doesnt save intake temps its just displayed live and id rather joe not be staring at a scanguage when he should be staring at the track. Even if we have to secure a camera looking at the temps and record a vid theough the seasion its better than having joe consentrating on it Edit : Even if we just take a look at the sangauge before he turns the engine off that might work, but it wouldnt be 'as' accurate.. Possibly might be enough tho.
Edited by chris_uk, 19 January 2012 - 11:57 AM.
#1223 The Batman
Posted 19 January 2012 - 11:56 AM
we can do this as i have my vbox with 2 cameras!
#1224 chris_uk
Posted 19 January 2012 - 11:58 AM
I have some more ideas for sat joe but we can go through them fri/sat.
#1225 siztenboots
Posted 19 January 2012 - 12:01 PM
any piece of data can be set to record Max / Min / Avg , I have a custom guage to record Max RPM , MPH and water temps.
#1226 The Batman
Posted 19 January 2012 - 12:02 PM
:lol: sounds dodgy i dont have a front splitter on at the moment which is annoying but one of those things...
#1227 techieboy
Posted 19 January 2012 - 12:18 PM
If you want to log the inlet temps, rather than just get a min/max/avg number from Scangauge, you could plug a bluetooth OBD reader into the OBD port and log that and any other data you wanted to a mobile phone and some OBD software like Torque. Cheap form of data logger for the various OEM sensors. Won't work on an iPhone though, unless you jailbreak it and install a proper bluetooth software stack on it. I'm going to come over on Saturday for a while anyway, so if I can find my bluetooth OBD adaptor, I'll bring that and a spare Android phone with me and we can give it a whirl, if you want?
#1228 CocoPops
CocoPops
  • 17,182 posts
Posted 19 January 2012 - 12:20 PM
Matt, you really do have all the toys!
#1229 techieboy
Posted 19 January 2012 - 12:24 PM
Techie by name, techie by nature. I do love a gadget. :blush: :D
#1230 The Batman
Posted 19 January 2012 - 12:25 PM
he really does doesnt he Imnotworthy go for it if you can buddy :groupjump: so what do i need to have then, an android phone along with a bluetooth obd reader cable?! this maybe the time i move to the dark side :o
#1231 techieboy
Posted 19 January 2012 - 12:37 PM
I think there might actually be a bluetooth OBD reader available for the iphone. But, from memory, as they had to get it officially approved by Apple (read - paid through the nose for the privilege) it was quite expensive. Like £120 and not £20.
Yep, Android phone (although older Nokia's N series phones can do it too) and a bluetooth OBD reader to stick in the OBD port. It'll work much better on the VXT ecu as that supports a faster communication protocol than the NA ecu does, so you should be able to either log more sensors/information or log stuff at a much faster rate. You might want to capture RPM, throttle position, boost or MAP (however that works) and IAT1 and IAT2 (if you have both). That will at least tell you what giving it some welly (or sustained welly) really does.
It's only a bit of halfway house between no logging and a proper setup like your Vbox with the plug-in logging upgrade but it will at least give you some data. Theoretically, you could probably export it and with some twatting about import it and overlay it on any video you've got. But that would probably be painful.
#1232 CocoPops
CocoPops
  • 17,182 posts
Posted 19 January 2012 - 12:43 PM
Can you have multiple OBD devices? or is it only 1 at a time?
#1233 The Batman
Posted 19 January 2012 - 12:44 PM
i will look into this and talk to you more about it on saturday!! i would love for my vbox to do it all but its rediculously expensive isnt it?
#1234 techieboy
Posted 19 January 2012 - 12:53 PM
I always thought it was just one device but I did stumble across something a few months ago that allowed you to connect up a second device at the same time but it was very expensive. Like $1500 or similar. :o
#1235 techieboy
Posted 19 January 2012 - 12:54 PM
It rapidly starts heading that way if you want the nice, easy to use, integrated option. :(
#1236 The Batman
surely all you would need is to just chop into the obd cable.. :blink:
#1237 techieboy
Posted 19 January 2012 - 12:57 PM
Think it's more complicated than that and the signals need to be multiplexed. :unsure:
#1238 The Batman
Posted 19 January 2012 - 12:58 PM
my laptops got bluetooth, can i shove it under the seat and let the data transfer to that :lol:
#1239 siztenboots
Posted 19 January 2012 - 12:59 PM
you can daisy chain scanguages with the standard cable
#1240 techieboy
Posted 19 January 2012 - 01:01 PM
You could. Not sure how much the hard disk in the laptop would enjoy it though. Still, at least you know once it's under the seat, it's never coming back out under it's own power again. :o
