Hmmm optional speed sensor sounds pretty good! Will have to look into that!
I'm going to fit an Led Chav light to it and put it on the dash somewhere so i can make sure that it is working! Also looking at fitting a timer to it or over ride so that I can keep it on after track abuse while the engine is off
I think Davies craig has made just the thing you need
Link to the gadget =]
Edit: You can hear it running when the ignition is turned on but once the engine is running its best to have a water temp guage to know if its still running
Edited by Ground Effect, 17 January 2011 - 07:45 PM.
