Adventure No.2
3266 replies to this topic
#161 FLD
Posted 04 February 2011 - 01:29 PM
come on Joe, keep up, where are the disks from?
mclarensboss , iirc
anyway, the harrup htv 1320 , this is now oem fit on the Evora S, wonder how much they are at Lotus prices.
Woo, thats good to know. I'll ask my lotus friend.
If they are cheap enough is there enough interest for a GB?
Edited by FLD, 04 February 2011 - 01:34 PM.
#162 Exmantaa
Posted 04 February 2011 - 02:03 PM
Machining the supercharger will not help you much. Good flowing/cooling inlet manifold, good head and exh. flow and map it well for high compression and E85. :rolleyes:
#163 The Batman
Posted 04 February 2011 - 02:04 PM
doubt it, courtenays tried doing one and no one was interested :lol: the harrop on the evora will have a different snout on it... dont think they are interchangable like the m62 if my memory is correct
#164 Gonçalo Pereira
Gonçalo Pereira
  • 46 posts
Posted 04 February 2011 - 03:35 PM
Joe can you please see what happen to the seat belts? They never get to Portugal. You cannot ignore the fact that i've already paid that a long time ago! I've send a lot of PM's and e-mails but you never answer! Sorry the off topic but was the only way to get your attention. Regars
#165 techieboy
Posted 04 February 2011 - 03:52 PM
E85. :rolleyes:
Not sure I've ever been in a petrol station that sells it in the UK. So, not much good if you have to go 100 miles out of your way to get it. :unsure:
Edit: Just checked and there's only 21 fuel stations in the UK that sell it. A good number of which seem to be in Norfolk, so handy for Courtenay's but not much else.
#166 Exmantaa
Posted 04 February 2011 - 04:28 PM
E85. :rolleyes:
Same in NL, not many sell it and more expensive than petrol... :angry2:
Water / Methanol injection than for knock resistance. thumbsup
#167 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 04 February 2011 - 04:39 PM
Water and methanol injection we might well be doing ;) :D :o
#168 Gonçalo Pereira
Gonçalo Pereira
  • 46 posts
Posted 04 February 2011 - 05:18 PM
#169 The Batman
Posted 04 February 2011 - 05:39 PM
water meth is what i will be doing, if i ever get my kit :poke: :lol:
#170 vocky
Posted 16 February 2011 - 04:36 PM
the new engine is coming along nicely :D
Saab 2.0 turbo converted to a 2.2 with a z22yh crank / eagle steel rods / wiseco 8.9:1 forged pistons.
The saab block has under piston oil jets and an oil cooler, the z22yh crank has a 60-2 trigger wheel and with the saab crank sensor should be able to run a z20let ecu :)
It has also been modified for an electric water pump :closedeyes:
Also attached is the M32 3.94 close ratio six speed gearbox Imnotworthy
#171 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 16 February 2011 - 05:14 PM
Looking good thumbsup Interesting to have electric coolant pump, what kind of strategy will that run and will you still use a thermostat?
#172 siztenboots
Posted 16 February 2011 - 05:19 PM
is that a non standard oil cooler setup attached to canister filter?
#173 techieboy
Posted 16 February 2011 - 05:23 PM
Nope, standard Saab oil cooler. thumbsup
#174 vocky
Posted 17 February 2011 - 11:28 AM
another pic
#175 FLD
Posted 17 February 2011 - 11:38 AM
Looks damn good! Are you going to paint the block? Whats the gearbox from? Its something I'm considering so knowing what the best box choice is might be useful.
#176 MaDFreeBiRD
MaDFreeBiRD
    VX gone :( 350Z replacement :D
  • 3,385 posts
Posted 17 February 2011 - 12:08 PM
should free up some ponies using a leccy water pump :P That engine is looking pretty
#177 Exmantaa
Posted 17 February 2011 - 02:41 PM
Sounds good, but no a fan of the lowish 8.9 compression on SC's. (Maybe for a boosted Harrop) How will that work out with head gasket ? Think the 8.9 is calculated for a std. 2,2 gasket so the thicker Saab item will lower it to ~8,5?? :glare:
Edited by Exmantaa, 17 February 2011 - 02:41 PM.
#178 vocky
Posted 18 February 2011 - 08:53 AM
yes once the wiring loom has been made.
the gearbox is a 2.2 with astra 3.94 internals which give similar gearing to the F23 4.17 box
the engine will rev very freely with a lightened flywheel and no balancer chain, so should free up some power
Mine is certainly fun to drive with the same set up :D
lowering the CR with forced induction seems to be the norm, plus this engine will have a Harrop at some point and the head will be skimmed so compression will still be around 9:1
#179 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 18 February 2011 - 09:00 AM
looking to good and when will it be finish :mellow:
#180 alanoo
alanoo
  • 1,324 posts
Posted 18 February 2011 - 10:19 AM
I never thought about that, but how do you run the oil cooler with an electric water pump ?
