Vxt Operation Garrett
Posted 28 October 2010 - 07:10 PM
Posted 28 October 2010 - 07:21 PM
Posted 28 October 2010 - 07:30 PM
Posted 28 October 2010 - 08:32 PM
Edited by MrSimba, 28 October 2010 - 08:33 PM.
Posted 28 October 2010 - 08:35 PM
Posted 28 October 2010 - 08:49 PM
Posted 28 October 2010 - 09:12 PM
Posted 28 October 2010 - 09:17 PM
Posted 28 October 2010 - 09:24 PM
Posted 28 October 2010 - 09:37 PM
Hello,
What size pistons are you specifying for your engine rebuild. Machining the bores out on an LET can lead to dangerously thin walls between the water galleries. I exploded an Z20LEH block which cracked and blew out shrapnel due to running 1.4 bar boost pressure. The max piston oversize escapes me 80. someat I'll check and cosworth is Mahle and OEM pistons on an LEH engine are very very good. I'm running an LEH cylinder head with LEH bottom end internals with a C20LET block with a Garrett G2871 bolted onto a custom exhaust manifold no AMM ecu runs off lambda and air temps.
Cheers
Ian
Danger, thanks for your feedback.
Are you saying that the CMS Cosworth and Mahle pistons are exactly the same and produced identically?
If I were to source a C20LET block, would this mitigate any issues of "thin walls between the water galleries"? What other implications, pro's and con's are there with substituting the block and non of the peripherals?
Zach
Posted 28 October 2010 - 09:55 PM
Zach you nutter!!!
So you needed a headgasket and that's your 'solution'... I salute you!!!!
'Man maths' at it's finest!!!
Sam.
Posted 28 October 2010 - 10:00 PM
Thank you for the kind-ish comments guys!
The freezing takes place after machining. I only know what is stated on their website, which also states that its not horrendously expensive. I have been trying to contact them today for exact prices. Ill keep trying and post exact prices when I find out.
The pistons are only over sized by .5mm in order to take up the slack from the re bore of the cylinders. I have heard about the cylinder walls being a weak point, which is why im so enthusiastic about the cryogenic freezing. I'm hoping it will help strengthen the block. I will know more when I get through to them on the phone. I have heard good things though.
Prices for the 'Performance White' ceramic coating are as follows:
£184 for the exhaust manifold
£125 for the turbo
£45 per foot of exhaust
All these prices exclude VAT and shipping is £15.
For the benefits and longevity that this has, especially for our application, I think this is well worth the money.
Zach
a couple of comments
I'd be carful, or more to the point need some reasurance, that the diferent thermal expansions of the block and liners is taken into account. Also from the papers I've read on it I'm not sure how much benifit it will be on Aluminium as the grain structure doesn't change in the same way as steel/iron.
As for ceramic coating unless you coat the internal surface of the componets then you'll increase the temperatures the metal reaches in turn increasing the stresses in the components and reducing the strength. You will however stop the heatsoak into the engine bay, but this is more of a problem with the tubular manifolds than the cast ones.
Zach you nutter!!!
Sounds like a 911 turbo eatin spec to me
Sam.
Lol! Sounds like it to me too!!!
When DG's finished tinkering it will be the fastest VXT in the country I've no doubt!
Edited by MrSimba, 28 October 2010 - 10:03 PM.
Posted 28 October 2010 - 10:23 PM
£125 for the turbo
Zach
Thanks for the feedback Winstar.
I have yet to talk to them in detail about the application of the freezing. But as it is a lardy ass'd iron block and the effect of the restructuring of the grain goes through out the metal and and not just the surface. This has to be a good thing? All the components are dipped separately so even if there were any mild expansion/contraction differences between the metals, it would be irrelevant as the block shall be bored to fit the pistons afterward.
I am aware of the stresses incurred by using thermal insulation. The main problem from this is when it is not evenly distributed, especially conman with wrap, which can cause localized stressed. This is normally when failures can happen. I am hoping to avoid this by having everything covered in a precise .3mm of the stuff. I spoke to the company about covering the internal surface also. They advice strongly against it as:
A It reduces the internal diameter of the pipe
B It is such a harsh invironment with the temperatures and flow of air, that the coating can't be guaranteed to stick indefinitely. If bits were to flake off and go through the turbo, this would not be good!
Posted 28 October 2010 - 10:29 PM
I wouldn't see which way you went if the road conditions aren't dry though!
Zach you nutter!!!
Sam.
I like the large power band with a big lump of mid-range torque, hence the reason for keeping OEM cams. It allows for effortless overtaking.
Posted 29 October 2010 - 08:06 AM
Posted 29 October 2010 - 08:08 AM
Posted 29 October 2010 - 08:10 AM
yet another garrett , yawn.
You know it makes sense Steve
Posted 29 October 2010 - 08:22 AM
Just looked at a few pics of the LET block and it doesn't have liners (doh!) will should be fine. I'm still dubious about how it can work on ali
The main stresses in a manifold are where the branches join and are function of the thermal expansion and the hotter it gets the more thermal expansion. Yes by keeping the metal the same temp through the thickness you reduce the bending stress component but the strength of metals also greatly reduces at very high temperature.
Holset FTW
Posted 29 October 2010 - 08:38 AM
