Vxt Operation Garrett
#61
Posted 19 January 2011 - 12:33 AM
#62
Posted 19 January 2011 - 10:36 AM
#63
Posted 19 January 2011 - 12:50 PM
#64
Posted 19 January 2011 - 01:32 PM
#65
Posted 19 January 2011 - 01:40 PM
#66
Posted 20 January 2011 - 01:04 AM
#67
Posted 20 January 2011 - 01:13 AM
its going to scare the bejesus out of me. Cant wait!
Sounds great!
#68
Posted 23 January 2011 - 05:38 PM
#69
Posted 23 January 2011 - 06:30 PM
#70
Posted 30 January 2011 - 08:53 AM
#71
Posted 30 January 2011 - 10:13 AM
This isn't the update that I would have liked to be giving. The gear box hadn't really felt right regarding smoothness of selecting gears (particularly 1st and 2nd), or even getting it into gear at all since having it back from the rebuild. Well im sorry to say that on the way to its 1000 mile engine oil change last week it gave in totally. With much clonking and grinding it has decided to create some kind of 1st-2nd gear hybrid which the gear stick seemingly has no control over (gear cables and connections have been checked). Obviously I didn't want to drive it in this condition and cause more damage by doing so. So once again I had the shameful ride home in a low loader with a sports car that you definitely can't run on £5 sitting behind me!
Zach
That is not good, sound like a selector fork problem, which is strange as when an ATB diff is fitted that part of the gearbox, with the gears and selectors remains untouched.
Ther is a problem with the gear selection and syncromesh with the F23, Vauxhall/OPEL sell a preassembled gear cluster.
Steve
#72
Posted 30 January 2011 - 09:54 PM
#73
Posted 31 January 2011 - 08:07 AM
Steve, I am not questioning your integrity. Especially as, apart from the odd anomaly e.g. the gear box having considerable amounts of water inside upon delivery, you have helped me out a lot and given me an abundance of useful advice/feedback, drawn from your considerable experience, pertaining to my build.
I just find it amazing, as in absolutely amazing, that this fault were to develop right down to the meter in time with the gear box being disassembled and failing. The difference in smoothness of gear changes was night and day between dropping it off back in Oct/Nov and then driving it for the first time a couple of weeks ago. In my optimism and excitement of having her back at long last, I was really hoping it was teething problems associated with running in a refurbished box. Or even something as simple as bleeding the clutch, which it has been proven to have had no air in the line. I drive like miss daisy anyway, but even more so since having her back due to running the engine in.
The exact cause of the failure is yet to be determined and shall only be clear once she is disassembled. Time will tell. Just a little disheartened at the minute due to the prospect of possibly spending more cash and the delays involved with fixing her.
Zach
Zach,
You are slightly missing the point, the gearbox was not refurbished, just a diff fitted.
The gearbox may prove to be beyond ecnomical repair, if that is the case and a replacment box is needed, I will swap the diff over for free while you wait, if you bring me the gearbox(s)
If you want the gearbox refurbished (rebuilt) I do not do that work, but I use a chap who used to rebuild the gearboxes for the works Ford rally team, again at cost.
Not to sure where the water come from, probably from when I jet washed the box, there was no sign of any water damage inside the box, which you or Duncan will see if either of you are there when the gearbox case is seperated.
Any questions please pphone I will gladly answer.
Steve
Edited by steveboyslim, 31 January 2011 - 08:16 AM.
#74
Posted 31 January 2011 - 10:19 AM
#75
Posted 31 January 2011 - 10:48 AM
#76
Posted 19 February 2011 - 12:07 PM
#77
Posted 14 March 2011 - 06:16 PM
#78
Posted 15 March 2011 - 08:00 AM
Edited by Duncan VXR, 15 March 2011 - 08:01 AM.
#79
Posted 28 March 2011 - 12:14 PM
#80
Posted 28 March 2011 - 01:15 PM
