Vxt Operation Garrett
#81
Posted 28 March 2011 - 01:40 PM
#82
Posted 28 March 2011 - 02:07 PM
Edited by Duncan VXR, 28 March 2011 - 02:08 PM.
#83
Posted 28 March 2011 - 02:43 PM
#84
Posted 20 April 2011 - 10:18 AM
#85
Posted 20 April 2011 - 05:12 PM
Good news. Thanks to Duncans and Steves efforts, I now have a fully functioning and ran in VX. I have driven an array of exotica since last August ranging from Renault Megane convertibles to 1.6 Focus Ghias. I am pleased to report that the VX is MUCH faster in a straight line and round the corners.
So, where I’m at compared with where I started:
Arrow Rods
Mahla Pistons
Under Piston Cooling
Up-rated Valve Springs
2bular exhaust (with cat unfortunately!(long story!))
Quaife ATB
New F23 gear box
I am guessing that the power will have risen from the 293bhp before to the low 300's. It certainly feels less restricted higher up the revs due to the larger exhaust. In fact, having been without it/not being able to give it billy big beans for so so long, it feels positively ballistic especially with the endless amounts of traction. I’m struggling to remember why I wanted any more power for the road. However, I'm sure ill get used to it and remember in no time!
Parts that have been purchased and still require fitment along with mapping:
Garret
CMS Exhaust Manifold
CMS Inlet Manifold
Equal diameter inlet piping
Larger injectors
This will be happening at an unconfirmed later date this year once my bank balance has recovered and Duncan can stand to look at a VX with out spontaneously combusting. Plus I want to make the most of the summer whether and abuse it again for a little while, maybe even a track day or two.
Zach
I can confirm the current setup is more than enough to work the diff and handling is spot on for the road, never driven a vx that drifts sooooo well. I love it!
#86
Posted 21 April 2011 - 09:52 AM
#87
Posted 21 April 2011 - 09:59 AM
#88
Posted 21 April 2011 - 10:03 AM
#89
Posted 19 June 2011 - 09:28 AM
#90
Posted 19 June 2011 - 12:18 PM
Zeb, have you had a chance to work out what you are going to do about the busted 2nd gearbox?
Fingers crossed for you.
Just got back from a week away not thinking about the VX. Im starting to loose interest to be honest as its turning into a bit of a money pit which doesn't seem to work for more than 5 mins! I need to speak with a couple of people about getting the box off again and replaced.
For people that don't know, my recently fitted F23 box has exploded in exactly the same way and in the same milage (1500 ish) as my first one, rendering the car undrivable again. The only thing that I can imagine it to be is the Quaife exerting forces back up through the box for what ever reason. Does anyone know if this is even possible or a likely reason? If so I might throw the ATB in the bin and just stick to a standard box in a bid for some reliability!
Good news on your power runs and good to know that the clutch is taking it with no probs. At least I know I have plenty of head room in that department.
#91
Posted 20 June 2011 - 08:55 PM
#92
Posted 22 June 2011 - 07:30 AM
As I said on the phone, the Quaife diff is not your problem and will not influence the way the gears are selected and will not affect reliability of the syncromesh or gear selection.
As the gear selector turret was used from your old gearbox maybe that is the problem.
Steve
#93
Posted 22 June 2011 - 04:07 PM
Steve
The gear changes were silky smooth for the first 1400 ish miles on the 2nd box with the selector turret from the 1st box. Are you suggsting the old turret could be causing premature failure of the syncromesh etc in the 2nd box?
#94
Posted 22 June 2011 - 07:06 PM
Steve
It could be possible.
Steve
#95
Posted 10 January 2012 - 11:47 PM
#96
Posted 11 January 2012 - 08:02 AM
#97
Posted 11 January 2012 - 08:16 AM
#98
Posted 11 January 2012 - 08:57 AM
#99
Posted 11 January 2012 - 09:02 AM
#100
Posted 11 January 2012 - 09:07 AM
It was but it looks like there is a solution to convert the siginal that the ECU can read
DG
