Offset For New Wheels
Posted 28 October 2010 - 10:01 PM
Posted 28 October 2010 - 10:27 PM
Posted 29 October 2010 - 10:28 AM
Posted 29 October 2010 - 03:16 PM
Posted 30 October 2010 - 04:43 PM
Any Pictures with them on the car yet?My 16/17 TD's were ET20 front and ET37 rear.
New Compo's that go on tomorrow are ET20 front and ET35 rear.
Both fronts were 7 inch wide.
Rear TD is 7.5 inch wide
Rear Compo' 8 inch wide, therefore the rears are going to stick out further than before.....
Is having the rears 8 inch wide going to make them catch the body work?
Posted 30 October 2010 - 06:36 PM
Posted 31 October 2010 - 12:00 AM
With the standard rear turbo alloy being 7.5 inch wide & the compomotive being 8 inch wide should we be going for a lower offset so the wheel is a little further away from the inner arch?
Edited by iVXT, 31 October 2010 - 12:11 AM.
Posted 31 October 2010 - 06:51 AM
Posted 31 October 2010 - 12:00 PM
Posted 31 October 2010 - 01:25 PM
Posted 31 October 2010 - 07:27 PM
Posted 31 October 2010 - 07:30 PM
7x16 front in et20 & 8x17 rear in et30
Edited by vocky, 31 October 2010 - 07:32 PM.
Posted 01 November 2010 - 09:39 PM
Posted 01 November 2010 - 10:57 PM
Has anyone been able to confirm the offsets on the speedlines for the vxr? and if they are defenatly 8 inch rears?
Not found out about the Speedline offset yet, done loads of searching/googling & posted on group buy thread as well as earlier in this thread.
Hopefully we can find out. Somebody must know on here, anybody help?
Found a link saying they're 7x16 & 8x17 here http://www.vxronline...hread.php?t=136 also I remember finding a pdf of the original vxr220 brochure, sure it said same but can't find that link now.
Cheers.
Posted 02 November 2010 - 09:03 AM
Posted 02 November 2010 - 01:47 PM
Posted 02 November 2010 - 07:15 PM
Posted 02 November 2010 - 08:47 PM
Postby jasvxt on Thu Sep 27, 2007 1:35 pm
Size front = 16" 7J Offset 26
Size Rear = 17" 8J Offset 35
PCD 5/110
Bore = 65.1 mm
Thanks for the info on these, do you have a thread link for this in case any more good info? Well done for finding. Also thanks Jason for the summing up the offsets.
So front et20 from et25 will make next to no difference handling wise other than will allow more clearance for/if you might get 4 pots in future. We might as well go et20 then just in case?
So rear et35 in 8j wide will clear inner arches without hassle as that is same as vxr speedline & I take it they don't catch or would et30 be better?
Thanks again everybody whose given input & sorry if were going on a bit about this but I want to get the best fit/handling possible from these & am sure other peeps in for the group buy would agree.
Cheers again.
Posted 02 November 2010 - 09:16 PM
