Lotus 116 Racing Project
220 replies to this topic
#201 GMS
GMS
  • 154 posts
Posted 13 July 2012 - 02:58 PM
Front view :)
#202 GMS
GMS
  • 154 posts
Posted 13 July 2012 - 03:00 PM
Latest update: Carbon canards :) Weight less than nothing :D
#203 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 13 July 2012 - 05:24 PM
A yellow version of Nevs car.... or the other way around I suspect , looks very mean! Track monster
#204 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 13 July 2012 - 05:45 PM
Nev got his body work from GMS. Same as Joe.
#205 GMS
GMS
  • 154 posts
Posted 23 July 2012 - 07:23 PM
Last weekend I had the 1000 km race. The car was fine and fast, we were at 5th place behind two LMP cars and two Porsches, but after 4 hours of race down pipe cracked and turbo gases burnt gear linkage cables :( We didn't have spare ones, so we had to retire from the race.
Here are some photos:
#206 Nev
Posted 23 July 2012 - 08:09 PM
What grade of metal was your downpipe made of Martynas? Maybe you should upgrade it to 321L or better with 2+ mm walls (ideally 3mm walls for super fat welds).
Edited by Nev, 23 July 2012 - 08:11 PM.
#207 cnrandall
cnrandall
  • 943 posts
Posted 24 July 2012 - 08:55 AM
On a race car it wants to be inconel
#208 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 July 2012 - 10:59 AM
Heeey!!! I'M # 23 !!!!!!!!!!!! :) Unlucky Martynas sounds like you're getting great reliability from the engine though :)
#209 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 24 July 2012 - 03:33 PM
Do you have std knuckles on or have you made something else to get the suspension geometry/ A-arm to be horizontal right? BR, Per
#210 Nev
Posted 24 July 2012 - 04:42 PM
As I remember, he has bespoke wishbones which not only alter the horizontal plane angle, but push the hub out a bit to the outside edge of the car. Im not sure if he uses OEM hubs though.
Edited by Nev, 24 July 2012 - 04:46 PM.
#211 GMS
GMS
  • 154 posts
Posted 25 July 2012 - 02:30 PM
Yes, we are using 321 grade steel, but we temporarily haven't found out the reason of cracking - it could be exhaust mounting problem. Chris, no doubt, inconel would be best solution :) If seriously, I hope you will give a few advices on welding the turbo manifold, because we will be making turbo upgrade in near future.
#212 GMS
GMS
  • 154 posts
Posted 25 July 2012 - 02:36 PM
right?
BR, Per
We have custom rose jointed wishbones. Hub centre in our custom upright is raised by 35 mm. Chassis mounting points remain stock according to FIA regulations.
#213 Nev
Posted 25 July 2012 - 02:37 PM
Maybe ring up Simpsons in England for a quote for an Inconnel manifold - it won't be cheap though :(
#214 GMS
GMS
  • 154 posts
Posted 25 July 2012 - 02:39 PM
Hey everybody, quick question. What is the difference in length between N/A and Turbo gear linkage cables (Because I want to order them today)?
#215 fezzasus
Posted 26 July 2012 - 12:28 PM
Don't know off the top of my head, but it might be listed here: http://www.vx220.org...es/page__st__60
#216 cnrandall
cnrandall
  • 943 posts
Posted 26 July 2012 - 12:39 PM
Talk to Chris Tullett, last quote I got for an inconel mani was £2.5K+VAT. That's expensive but much less expensive than dumping 1000k races in the bin.
#217 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 26 July 2012 - 12:44 PM
About 6cm
#218 GMS
GMS
  • 154 posts
Posted 30 July 2012 - 01:14 PM
About 6cm
Thanks for info. Ordered ;)
#219 GMS
GMS
  • 154 posts
Posted 28 September 2014 - 01:21 PM
Last weekend's testing at Nemun Ring with one more interesting machine B)
#220 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 28 September 2014 - 07:08 PM
Looks like a great weekend. Car is looking very good!
