Vx220 Heater
Posted 30 December 2010 - 04:07 PM
Posted 30 December 2010 - 04:11 PM
Posted 30 December 2010 - 04:38 PM
Posted 30 December 2010 - 07:02 PM
Posted 30 December 2010 - 08:54 PM
Posted 30 December 2010 - 09:03 PM
Posted 30 December 2010 - 10:20 PM
Posted 30 December 2010 - 10:25 PM
Posted 30 December 2010 - 10:58 PM
Posted 30 December 2010 - 11:25 PM
Edited by smiley, 30 December 2010 - 11:28 PM.
Posted 30 December 2010 - 11:28 PM
Posted 30 December 2010 - 11:42 PM
Posted 31 December 2010 - 12:35 AM
Posted 31 December 2010 - 07:52 AM
Posted 31 December 2010 - 09:38 AM
Hi Adam, my old heater will be on its way first thing tomorrow, sorry for the packaging!!
I told you guys if we all club together we could fix this on going problem, perhaps now we will!
As per your e-mail, flow is poor and the heat is poor too.
Slindborg do you think your temperature problem might of been down to the bypass thing you made for yours? the original heater always cools the water in the matrix, just diverts the warm air into the cabin if needed??
This will have to be the best mod if we pull it off.
ITs NOTHING to do with the bypass.... As I've had it bypassed for nearly 2 years now and had never had issues.
The problem is if you take too much heat out of the matrix the return water is a LOT cooler than the coolant in the engine and due to the lotcation of the return on the N/A it causes the thermostat to shut driving up the engine temps. I was seeing a 10deg rise then fall over a fairly stable time base when using MK1 of my heater design. Hence the less efficient MK2 which is 50% made and less than likely to ever be tested
Posted 31 December 2010 - 11:53 AM
Posted 31 December 2010 - 12:00 PM
Posted 31 December 2010 - 12:20 PM
Posted 31 December 2010 - 12:57 PM
Depending on the design of the heater could we not change the thermostat for a slightly different temp one to compensate it?
I'm guessing you'd possibly bring on other problems when you're not using the heater.
I think this is possibly too much being looked at, Slinborg mentioned what happened with his modified setup, with a bigger matrix (I think) he also had an fan that possibly pushed a lot more air.
Going by others that have a good heater there's more than heat entering the cabin, so as long as the matrix in the after market box isn't too much bigger it shouldn't be a problem I'd guess.
The main issue with the OEM heater is it's they're rubbish in construction and will become like hens teeth as time goes on, hopefully this after market one comes through
Edited by Bargi, 31 December 2010 - 12:57 PM.
Posted 31 December 2010 - 01:18 PM
used the OEM matrix and the merlin fan....
I'd say the heater dumps more than enough heat out, just it needs to be routed and fanned properly
