Edited by atom x, 10 January 2011 - 08:48 PM.
Centre Driver Position
Posted 10 January 2011 - 08:39 PM
Posted 10 January 2011 - 08:41 PM
Posted 10 January 2011 - 08:45 PM
Posted 10 January 2011 - 08:48 PM
Might be worth finding one and having a poke around
Bit more info here at the bottom
Posted 10 January 2011 - 08:51 PM
Posted 10 January 2011 - 09:00 PM
The other major advantage of centre position is safety for sideways impact.
And also, not having to put up with passengers.
Posted 10 January 2011 - 09:16 PM
Posted 10 January 2011 - 09:22 PM
Posted 10 January 2011 - 09:27 PM
There's a lot of flex in the floor, not sure whether that would be compatible with floor mounted pedals.
Isn't the latest Nitron Exige a centre seater?
I will open up the void area first and see how much usable room there is
I will then decide the best pedal box option with reinforcing if required
I may be able to just move existing pedals lateraly into the centre, not ideal as I really want to move pedals forward
Posted 10 January 2011 - 09:32 PM
GEARSHIFT & HANDBRAKE
Gear lever will be between your legs, handbrake ...that could be painful.
Posted 10 January 2011 - 09:38 PM
Already stated re-locate mechanism
or
I could re-locate little Stig & his two assistants
Edited by atom x, 10 January 2011 - 09:50 PM.
Posted 10 January 2011 - 09:43 PM
Posted 11 January 2011 - 09:44 AM
Some lights around the rear-view mirror with which to admire yourself?Have I missed anything
Posted 11 January 2011 - 10:22 AM
Posted 11 January 2011 - 11:42 AM
Posted 11 January 2011 - 01:09 PM
Posted 11 January 2011 - 01:18 PM
Posted 11 January 2011 - 05:53 PM
considering most uk circuits are clockwise, you would be better with ballast on the drivers side, ie. not change anything
I will let Adrian Newey know that "he got it wrong"
Edited by atom x, 11 January 2011 - 05:54 PM.
Posted 11 January 2011 - 10:45 PM
Your sanity?I am intending to convert VX220 to a single seat with a central driving position.
Awesome mod, can't to see pictures of the work in progress and finished article
Posted 13 January 2011 - 03:48 PM
proposed seat from JK Composites
Tis is the same as JJJ but with higher sides, wider bottom AND more relaxed driving position it is called Ultima maybe it should have the strapline IDEAL FOR FAT LAZY OWNER
image of elise motorsport cabin
Copy of image referenced earlier in this thread
Edited by atom x, 13 January 2011 - 04:01 PM.
