Stack Help
26 replies to this topic
#1 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 18 January 2011 - 11:30 PM
Hi all, thought I'd be clever and change the colour of the LEDs in the stack. However now they are working but very dim. Looks like earth leak, but they never get brighter. I think I have assembled the stack wrong, and that the very small nuts on the back actually go on inside the cover to earth the circuit board inside or does the earth for the lighting go though a wire that may be broken. For the record the remainder of the stack works perfectly.
#2 vocky
Posted 18 January 2011 - 11:34 PM
I don't think the nuts provide an earth for the stack leds because they were all soldered direct to the pcb on all the stack dashes I've pulled apart
#3 Winstar
Winstar
  • 4,264 posts
Posted 18 January 2011 - 11:39 PM
may be stating the obvious have you tried turning the brightness up?
#4 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 19 January 2011 - 08:48 AM
:lol: First thing I thought too. Hold down the "reset trip mileage" button next to the key and it cycles through brightness'
#5 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 19 January 2011 - 02:40 PM
Yes I have tried the brightness thing. :rolleyes: even in it "brightest" setting it is so dim that I can't even see the dials in the pitch black. I hate electronics :( Can anyone who knows about this sort of thing help me out? Willing to travel to you with my stack if necessary?
#6 slindborg
Posted 19 January 2011 - 03:28 PM
chances are you have either fitted dimmer then std led's, OR you have fitted bright ones but they are such a narrow band you see them dimmly on the dash, OR they need more current than the originals and the inline resistor is too high.
#7 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 19 January 2011 - 03:42 PM
Thing is, when I first tested them before I put it all back together they were bright, but flickered. Seemed like and earthing issue so I assumed some of the stack earthed through the chassis. But when I put it all back together they stopped working properly. They are PCDs, but the stack has cone shaped "spreaders" about each buld so directional shouldn't be an issue. I checked the polarity of the old bulbs very carefully before I replaced these and have double and triple check they are all wired in the correct way round :( The only reason they are on at all looks like because there is earth leak (similar to when the interior light is changed for an LED bulb)
#8 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 20 January 2011 - 01:44 AM
They must be extremely dim if that's the case. It's like they are not getting full power to them at all. :rolleyes:
#9 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 20 January 2011 - 12:44 PM
:yeahthat: Precisely. But I don't know how to check that or which wires I should be checking. I hate electronics thumbsdown Anyone know where there is a wiring diagram for the internals of the stack unit? And also for the wires going in I guess is just in TIS?
#10 slindborg
Posted 20 January 2011 - 12:50 PM
you wont find a schematic of the inside of the stack. The TIS wiring diagram will tell you how to connect it up though (cant believe you even did this 'project' knowing you hate/cant do electronics :lol:)
#11 Jameshs
Jameshs
  • 3,511 posts
:yeahthat:
Why play with them if you dont understand them :rolleyes:
#12 d4nnyk
d4nnyk
  • 769 posts
Posted 20 January 2011 - 01:24 PM
What colour led did you go for?? not that it would make a difference
#13 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 20 January 2011 - 01:35 PM
black by the sounds of it.
#14 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 20 January 2011 - 01:39 PM
:lol:
#15 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 21 January 2011 - 12:05 PM
:lol: currently black, but actually should be white. I did it suceccesfully with my clio. Now have lovely white instruments with blue screens. even managed to do the radio and the a/c and all the button/window switches etc and just need to make up a board to do the clock bit as currently it's bulbs... But the stack has flummoxed me :( :beat: I can't understand why they only partially work. so they clearly are in the correct way round etc. Any one offer any solution? I am a numpty (for the record I also have sucessfully done all the switches with white icons and blue indicators and they look ace thumbsup ) Happy to advise anyone wanting to do that themselves despite the proof above of my allergy to electronics!!
#16 Jameshs
Jameshs
  • 3,511 posts
Posted 21 January 2011 - 12:08 PM
What did you remove and what did you replace it with. Have you checked the spec of both parts??
#17 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 21 January 2011 - 12:38 PM
Well I removed the original LEDs and replaced with these
not sure what the spec is of the stack ones? perhaps these would be better matched?
#18 slindborg
Posted 21 January 2011 - 02:48 PM
in short, if they are dim they need more current...
#19 d4nnyk
d4nnyk
  • 769 posts
Posted 21 January 2011 - 03:55 PM
I am no auto electrician and problem talking a load of b*ll*cks but if there is 12v running through the stack to light the leds and there are six leds then in theory each led would have to only require 2v to be on maximum brightness?? Am I talkng sh*t???
Edited by d4nnyk, 21 January 2011 - 03:55 PM.
#20 slindborg
Posted 21 January 2011 - 04:24 PM
Am I talkng sh*t???
talking sh** lol
They wont be in series, or atleast shouldnt be.
They most likely wont take 2v, most LED's dont thesedays
