Custom Front Clam
48 replies to this topic
Poll: Custom Front Clam (44 member(s) have cast votes)
Which?
  1. OEM+ (24 votes [54.55%])
    Percentage of vote: 54.55%
  2. Top Bar Added (16 votes [36.36%])
    Percentage of vote: 36.36%
  3. Top Bar Added, Fogs In Mesh (4 votes [9.09%])
    Percentage of vote: 9.09%
Vote Guests cannot vote
#41 techieboy
Posted 19 January 2011 - 02:40 PM
I've got a couple of those vents and even went as far as trying to mock up a back section with an outlet for ducting to the brakes. Even toyed with blanking the inner half of it off, so that a fog/driving light could go in there as I thought there might be too much air. At one point I even went as far as seeing if I could get something like the Focus RS bumper vents to try and do something fancy like shrouding the wheels/tyres. Then realised my enthusiasm far outweighed my ability to do anything like that. In the end, I decided it was pointless wrecking a perfectly original clam and put the vents on the shelf until the day something happens that requires some GRP work to the front. :rolleyes: For what it's worth, I'd do as RobNA suggested. thumbsup
#42 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 19 January 2011 - 02:57 PM
thumbsup
#43 techieboy
Posted 19 January 2011 - 03:07 PM
Yep, that's the fella. Couldn't find them anywhere without buying a Focus RS bumper which likely would have meant I'd have ended up buying the car to go with it (I'm an RS man at heart). :rolleyes: Found some pokey looking Subaru vents but thought the Focus RS looked better and would probably follow the arch line better.
#44 Darcini
Darcini
  • 2,508 posts
Posted 19 January 2011 - 11:29 PM
Fashioned a shroud from fibreglass to fit over the back of the vent
http://Posted Image
Next pic shows the silicone hose attached from DucattiSenna's excellent brake cooling kit
http://Posted Image
Would recommend sealing the back of the vents/clam to stop any moisture entering the fibreglass and creating any oem style bubbling thumbsup
Edited by DARCINI, 19 January 2011 - 11:41 PM.
#45 Darcini
Darcini
  • 2,508 posts
Posted 20 January 2011 - 12:15 AM
Ok, try again now I know what I'm doing
Did someone mention a carbon V?
And for Fred's next project............
Only at the pattern stage so far, need to take a mould of it next
#46 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 20 January 2011 - 12:20 AM
That looks good in that pic. thumbsup
#47 fred666
fred666
    All Show, All Go
  • 2,291 posts
Posted 20 January 2011 - 01:00 AM
Darcini i did actually acquire some foam blocks and started a few drawings for a rear cover, with clear slats... but with no hard top i decided it would look a little wrong lol I have no plans for anything like that now. Fair play though that looks amazing, do you work with fibreglass for a living? Bodyshop or anything?
#48 Ground Effect
Ground Effect
  • 151 posts
  • Interests:Crackle Free Vinyl, The Universe and how the fcuk we got here :-l
Posted 20 January 2011 - 01:58 AM
Fred: I voted for version 1. less is more ;) Darcini: That boot cover looks nice, is it going to hinge upwards with the just the rear storage cover and lock attached to it :poke: :P Youve taken the original mesh out of the OEM boot so you must be doing something a bit diffrent, whats the plan ?! ;) Sam.
#49 Darcini
Darcini
  • 2,508 posts
Posted 20 January 2011 - 07:54 PM
Fred666 "Fair play though that looks amazing, do you work with fibreglass for a living? Bodyshop or anything?" :D far from it mate, just an enthusiastic (dependent on the weather) amateur. I mean, how hard can it be? ;) Sam "Darcini: That boot cover looks nice, is it going to hinge upwards with the just the rear storage cover and lock attached to it :poke: :P Youve taken the original mesh out of the OEM boot so you must be doing something a bit diffrent, whats the plan ?! ;)" I have considered trying to attach to a modified boot section and hingeing from the roll bar, but decided that was way outside of my abilities. It will be an easily removable panel using aerocatches or similar, retaining the the original engine/luggage cover. I was originally going to use the oem mesh from the boot in the new aerodynamic (!) cover but it didn't look right, can't decide whether to go for mesh or a louvred slats type of look......
