Gearbox Oil What's The Best?
82 replies to this topic
#41 vocky
Posted 10 January 2013 - 05:42 PM
wow, that was a long time ago :mellow:
#42 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 10 January 2013 - 08:29 PM
Sure was. I had less hair, less wife and less kids back then :D Question: Can the gearbox and engine be removed and installed as a single unit from a VX (with rear clam off)? Or do they have to be split? I'm assuming it won't be a problem.
#43 Dave H
Dave H
  • 234 posts
Posted 10 January 2013 - 10:49 PM
If its a turbo, disconnect the rear hubs, swing out of the way so you can remove the drive shafts and the lump will lift out.
Dave
#44 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 10 January 2013 - 11:16 PM
Thanks Dave. It's an na. If you can do it with a turbo I'm guessing the na should be a similar job. Any idea on the crane size. I have a 1 ton trolley crane.
#45 siztenboots
  • 26,613 posts
Posted 11 January 2013 - 08:45 AM
managed it okay on a turbo with the rear clam still on
#46 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 January 2013 - 10:18 AM
Imnotworthy Liked to have see that. Did you bring it out the top or bottom?
#47 siztenboots
  • 26,613 posts
Posted 11 January 2013 - 10:27 AM
bottom , no way you could get it out the top
#48 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 January 2013 - 10:54 AM
So you've no magic then :jump: I'd have to dig out a beer cellar. :D Garage roof is way to low for hoisting a car.
#49 thejoaoserra
thejoaoserra
  • 216 posts
Posted 18 May 2015 - 09:51 AM
So, final conclusion, whats the best oil for a 2.2 gearbox? GM stuff, Castrol SMX-S, motul 300 gear or another?
#50 fezzasus
Posted 18 May 2015 - 02:00 PM
GM if available.
Basically, gear oil specifications are not made available to other companies. It is an agreement between the OEM, the lubricant supplier and the additive supplier. The ONLY way to be sure you are getting the correct stuff is to buy the GM stuff.
#51 slindborg
Posted 18 May 2015 - 02:05 PM
Does gearoil go off? I've got some GM stuff in unopened bottles in the shed :lol:
#52 furtive
furtive
  • 1,134 posts
Posted 18 May 2015 - 02:13 PM
Does it have a sell by date? You can come and pour it into my gearbox if you want to clear some space in your shed ;)
#53 Nev
Posted 18 May 2015 - 02:31 PM
I use cheapo Halfords stuff. Works fine and takes more torque more regularily than anyone else's gearbox and has done for approx. 40,000 miles. The standard thickness can cause some whiring sounds at high RPM (ie 6000 to 8000), so something thicker would likely be a bit less noisy. Both of my gearbox oil changes have been ultra clear/clean in the past, both the OEM Vauxhall red stuff and cheapo Halfords stuff. In short it's not worth even a second thought IMO, though I sure more people who have a vested interest will argue the toss with an excess of techno babble.
Edited by Nev, 18 May 2015 - 02:36 PM.
#54 thejoaoserra
thejoaoserra
  • 216 posts
Posted 20 May 2015 - 05:43 PM
Many thanks to all of you! I'm going to buy either gm stuff or motul 300 gear, depends on what's going to be easier to find and cheaper. Regarding quantity, just a bit over 2??
Edited by thejoaoserra, 20 May 2015 - 05:44 PM.
#55 fezzasus
Posted 20 May 2015 - 08:59 PM
Yes... sort of. There are suspensions of material, give it a good shake before you use it.
#56 martinroger
martinroger
  • 459 posts
Posted 18 February 2017 - 11:25 PM
Bumping this up. Where does one find the GM stuff ? Vauxhall dealership ? Or there are better deals elsewhere ?
#57 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 18 February 2017 - 11:56 PM
Autovaux
Edited by ditonics, 18 February 2017 - 11:56 PM.
#58 martinroger
martinroger
  • 459 posts
Posted 19 February 2017 - 12:06 AM
Autovaux
Thanks!
#59 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 19 February 2017 - 09:06 PM
Use this one like Opieoils recommend. Has the oem GM number on it! (look with specs) http://www.opieoils....sion-fluid.aspx
#60 martinroger
martinroger
  • 459 posts
Posted 19 February 2017 - 09:11 PM
I went for the Motul Motyl this time... I'll see what gives !
