Use this one like Opieoils recommend. Has the oem GM number on it! (look with specs) http://www.opieoils....sion-fluid.aspx
I went for the Motul Motyl this time... I'll see what gives !
I'd be very careful using anything other than GM branded gear oil, unlike engine oil, gear oil doesn't have published specifications, so no one knows exactly what the vehicle manufacturer wants when trying to design an aftermarket oil.
They do some testing, and it seems to be okay. The oil company will then state something like 'suitable for use with...', but the car manufacturer has never approved the lubricant for use, or seen any data to suggest the product is suitable.
Manual transmissions are relatively simple so it's probably not the end of the world, however i'll stick to using the GM stuff.
