Exige Bilsteins
9 replies to this topic
#1 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 25 January 2011 - 10:38 AM
Morning! I know some of you have Bilsteins taken from various Lotie on your cars so here's a quick question for those in the know... I've got a 2.2 NA. Will these shocks from an Exige fit and are the spring rates correct? Front: Damper - Bilstein F4-BE3-A677-TO (A122D0007H) Spring - Eibach 14/04 - 47.5N/mm (A122D0008) Rear: Damper - Bilstein F4-BE3-A678-TO (A122D0008H) Spring - Eibach 15/04 - 65N/mm (A122D0006) Thanks in advance!
#2 SteveA
SteveA
  • 9,151 posts
Posted 25 January 2011 - 10:48 AM
Could probably do with softer springs on the rear by about 25lb/in but it's not a million miles off.
#3 Paulus H
Paulus H
  • 2,063 posts
Posted 25 January 2011 - 10:54 AM
Not long since covered this.
The general opinion was that Toyota engined Exige std springs and dampers would be fine.
http://www.vx220.org..._1#entry1127524
Paul
#4 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 25 January 2011 - 10:56 AM
Not sure if you can tell from that information but other than the rear spring rates will these be a direct replacement for OEM suspension? i.e. ride height etc? Thank you!
#5 techieboy
Posted 25 January 2011 - 10:58 AM
Apparently raises the front ride height slightly (<10mm) unless you fit the Elise Parts front damper mounts.
#6 Winstar
Winstar
  • 4,264 posts
Posted 25 January 2011 - 11:00 AM
Morning!
I've got a 2.2 NA.
Front:
Rear:
Thanks in advance!
Yes they do, they are what I've got on the car.
As for spring rates the stiffness ratio is the same as Randy recomended for Restet's NA, which is good enough for me.
edit: results in 5mm increase in ride hight (upto 145mm from 140mm) I took all the measurements to get some custom springs made to drop it but CBA. Maybe I should look at organising a group buy
Edited by Winstar, 25 January 2011 - 11:04 AM.
#7 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 25 January 2011 - 11:04 AM
Morning!
I've got a 2.2 NA.
Front:
Rear:
Thanks in advance!
Brilliant :)
Did you find any change in the ride height?
#8 Winstar
Winstar
  • 4,264 posts
Posted 25 January 2011 - 11:10 AM
Brilliant :)
see edit
#9 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 25 January 2011 - 11:17 AM
Cheers. Could certainly see what interest there was in a group buy for brackets. I remember getting some made up for my S1 Elise but cant remember where I got them done now.
#10 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 25 January 2011 - 05:35 PM
Having fitted them to mine I am very happy. TBPH if the ride height has increased then I have yet to notice. The whole car feels more together and because I am not budding Schumy I doubt changing the damper mounts would feel like a worthwhile effort. But the OP sounds like youdrive you car a bit more keenly than I so could be worth it.
