No oil coolers. Additional pre rads. Despite having the Pro Alloy Charge Cooler System which did a good job with 290BHP, now having some 375BHP the IAT after several motorway accelerations from 100kph up to 250kph+ rose up to 60 degs C. Even with a bigger pump no real gain. Furthermore the IAT needed some 4 minutes(!) of constant low power driving at 120kph to get back down to a normal level.
That was far from optimal!
you don't have the problem Nick did with the fans running in reverse?
Nope.
Double checked this back in 2010 when I dropped in the PA Pre Rad.
"60 is not bad"... Must admit that I am kind of a perfectionist. "not bad" = "not OK".
There are three reasons for trying getting the temperature below 55 degrees:
1) Track day use, power loss after few minutes of driving.
2) Quartermile, power loss after very few turns in a row.
3) Motorway performance, power loss from standing still beginning below 200 kph and lengthen the time for getting up to top speed (~285 kph) significantly.
Power loss is a no-go-criterium.
