Heater delete?
Project 'i Want To Go To Work Today'
#201
Posted 12 September 2013 - 07:10 PM
#202
Posted 12 September 2013 - 07:13 PM
#203
Posted 12 September 2013 - 07:16 PM
Heater delete?
Not likely, my other 'daily' is a road bike. This is my luxury car.
#204
Posted 12 September 2013 - 07:18 PM
Next job will be a lightweight boot lid, was amazed at how heavy it was. don't want to take too much weight from the front given the already dubious weight distribution.
#205
Posted 12 September 2013 - 08:24 PM
Are you going to de-skin the original lid or get one of those weird humpy ones?
#206
Posted 12 September 2013 - 08:28 PM
Current thinking is to make a mould from the rear support and fit to a CF sheet with a foam core.
#207
Posted 12 September 2013 - 08:30 PM
Can it be painted to look oem finish?
#208
Posted 12 September 2013 - 08:40 PM
I hope so, I actually like the standard VX look so i'm trying to keep it that way. If I can finish the subwoofer enclosure I started months ago (mostly for proof that I can work with fibreglass) then I'll look at getting a boot lid to mould from.
#209
Posted 12 September 2013 - 10:38 PM
#210
Posted 13 September 2013 - 06:11 PM
Engine's done 85k so I'm resisting any modifications to the engine based on the limited returns from doing it to a high milage engine, will certainly be cutting the cooling tank bracket. Also got a Larini which is basically a pipe so lots of weight saving there
#211
Posted 14 September 2013 - 07:08 AM
#212
Posted 26 September 2013 - 06:33 PM
2 kg saving today.
Plastic rocker cover - 2.2 kg,
aluminium rocker cover - 3.6 kg
engine lifting mounts 4 x 200 g
Therefore total loss = 3.6 + 0.8 - 2.2 = 2.2 kg
so far 12.9 kg
#213
Posted 27 September 2013 - 07:59 AM
I haven't included it up to now as I intend to change it, but I've also got a Larini backbox on which weighs 7 kg compared to the OEM 11.2 kg, so currently saved 17.1 kg total
#214
Posted 27 September 2013 - 08:05 AM
I only saved 4.8kg swapping to TD 1.2's (888 tyres)
oh and
Nitrons + brackets = 9,997g Billies + brackets = 11,009g
#215
Posted 10 November 2013 - 03:53 PM
Quiet car time.
Pipercross Venom VM7000 filter, with larger intake duct to reduce restrictions and silicon reducer rather than rubber.
Turbo back box with Europa U bend and additional flange to fit.
#216
Posted 10 November 2013 - 03:55 PM
has it made it quieter
#217
Posted 10 November 2013 - 03:56 PM
Pipercross certainly has, don't know about the exhaust yet, but it's got to be quieter than a Larini!
Edited by fezzasus, 10 November 2013 - 04:18 PM.
#218
Posted 10 November 2013 - 05:08 PM
Full specs, because why not.
Engine
Eaton M62 supercharger with 3.1" pulley,
dual pass modified intake manifold,
15 l/min charge cooler pump,
pro alloy charge cooler,
VXR injectors,
OBD tuner software.
working PCV.
EGR delete (and disabled in ECU - means software doesn't vary fuelling and timing advance thinking EGR is connected)
approx 260 bhp and 325 nm torque (calculated by OBD tuner)
Deleted pre-cat
Turbo backbox
Pipercross Venom air filter, 3" intake piping to minimise restrictions
General mechanicals
Elise-shop toe links - fitted at approx 70k
Refurbed steering rack with brass cups - fitted at approx 65k
Elise-shop/cablecraft gear cables - fitted at approx 75 k
New rear calipers - fitted at approx 83 k
new secondary handbrake cable - fitted at approx 83k
Upgraded heater (obvs)
Braided brake lines - fitted at approx 80k
Lotus 4 channel ABS - fitted at approx 86k
All aluminium radiator - fitted at approx 60 k.
Larger horn - fitted at approx 60k
VW wiper relay
Poly engine mount inserts - front and rear. fitted approx 65 k
Replaced side engine mounts - approx. 65k
Interior
Carbon dash plates, door card inserts and door triangles.
Leather covered centre console.
Alpine head unit with Imprint sound calibration
Front speakers in dash vents
Covered dash and binnacle with carbon fibre surround.
Acoustic thinsulate insulation behind bulkhead
Think that covers it :s
Edited by fezzasus, 10 November 2013 - 05:09 PM.
#219
Posted 10 November 2013 - 05:18 PM
Finished painting?
#220
Posted 10 November 2013 - 05:28 PM
Finished painting?
I've stopped for the winter - it's too cold to spray outdoors and frankly I don't have enough daylight to get it done. New plan is to make a few lightweight CF parts and spray them purple before they go on. First up is the roll bar cover with the head rest cut outs removed and then boot lid.
