Project 'i Want To Go To Work Today'
488 replies to this topic
#321 Bargi
Bargi
  • 4,483 posts
Posted 15 May 2015 - 08:46 PM
Seriously, 11 months later you comment? You need a job!
#322 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 15 May 2015 - 10:59 PM
Seriously, what is happening with your car?
#323 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 16 May 2015 - 05:36 AM
Looking good Tom, made me want to go out and get some chocolate.
#324 JG
JG
  • 13,612 posts
Posted 16 May 2015 - 05:40 AM
You don't have a stash of chocolate in the house? :o
:P
#325 fezzasus
Posted 16 May 2015 - 02:46 PM
Currently, nothing. Still needs the engine fitting. Some major DIY has taken priority over it, but that's almost at an end now.
#326 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 16 May 2015 - 03:58 PM
Are those units made from painted chipboard?!
#327 fezzasus
Posted 16 May 2015 - 04:01 PM
just the doors are stained OSB, the carcasses are from Ikea
close up
#328 fezzasus
Posted 01 June 2015 - 05:46 PM
Back to the car!
3.0" Tullett manifold and 200 cell cat ordered. Should mate with the 2bular backbox I have (I hope :s)
Engine specs, if I haven't listed already:
Saab B207(R?)
2.0 L (86 x 86 mm)
Comp cams stage 2 blower
Dbilas valve springs (single coil, 93 kp)
balancer delete
original pistons (Z22SE pistons are rated to 300 bhp, I'm expecting more from these due to the under piston oil jets)
original con rods - good for 400 bhp
original crank - good for far more power than i'm generating.
Eaton M62
LSJ inlet manifold
Matt Bentley flywheel 4.5 kg.
External crank trigger
retain Saab oil cooler.
Will be taking the chance to get the subrame off and reshim
#329 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 01 June 2015 - 06:24 PM
Same spec as mine apart from I have LSJ stage 2 cams and a harrop. What is your reason for keeping the Saab oil cooler? Speaking to vocky when mine was being built he said to keep the OEM one as it's a like for like swop and much better design. What pulley size and power will you be aiming for?
Edited by ArticMonkey, 01 June 2015 - 06:24 PM.
#330 Kieran McC
Kieran McC
  • 3,416 posts
Posted 01 June 2015 - 06:41 PM
With the m62 and a 2.9 pulley you should be around 290 bhp, The m62 is nearly on the max at that, the 3" exhaust will help more than my 2.5"
#331 fezzasus
Posted 01 June 2015 - 06:44 PM
Age and packaging, the original one sags and moves, while the saab is fixed, additionally I think a brand new one is less likely to fail than a 14 year old one.
I've got a 2.9 pulley right now. I expect around 300 bhp, although my main target is safe power (unlike the old engine!)
#332 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 01 June 2015 - 07:11 PM
Will you be keeping the cam cover pump for your brake servo pipe? I've found it's made a noticeable difference to the peddle feel. Also are you following chills PCV breathing system with catch tank and vacuum from the filter pipe?
#333 fezzasus
Posted 01 June 2015 - 07:52 PM
I think I will, it's a tiny parasitic loss compared to that of a supercharger.
I will look into more passive PCV systems, a lot of truck engines have good oil mist separators.
#334 fezzasus
Posted 04 June 2015 - 12:42 PM
Will be using one of these with the PCV setup. https://www.mann-hum...ent_en_2013.pdf (PrroVent 200)
#335 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 04 June 2015 - 12:49 PM
How much?
(Nev would need the ProVent 800 with his bhp :lol: )
#336 fezzasus
Posted 04 June 2015 - 12:59 PM
Around £120 http://www.inlinefil...reathers/Engine
#337 fezzasus
Posted 09 June 2015 - 07:50 AM
Fluids ordered. Turns out that Vauxhall was £30 cheaper than Opie Oils. No dodgy oil advice, and a money saving - win.
#338 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 09 June 2015 - 09:58 AM
What oil did you to for in the end? I'm still on running in oil but will need to drop it out soon.
#339 fezzasus
Posted 09 June 2015 - 10:02 AM
GM Dexos 2 oil; it's the same additive system using in Motul 8100 x-clean, which i'm recommending to people.
Not going to bother with running in oil, it may have helped back when flat tappets were used, but modern engine tolerances don't really need anything special. I'll just change the filter after 500-1000 miles and top the oil up.
#340 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 09 June 2015 - 12:28 PM
This correct? http://www.amazon.co...S/dp/B007QMR5VW
