Got mine from Autovaux - http://www.autovaux....exos2-opel.aspx
Project 'i Want To Go To Work Today'
#341
Posted 09 June 2015 - 12:42 PM
#342
Posted 04 July 2015 - 10:47 AM
Exhaust system sorted.
2bular 3" backbox.
Tullett cat and manifold.
Was hoping to start on the car this weekend, but I broke my Vectra while collecting the parts from Tullett. I suspect it's DMF failure, however the noise persists (sounds like stirring coal) with the clutch both engaged and disengaged... I'll know more come Monday (unless anyone has any suggestions).
Edited by fezzasus, 04 July 2015 - 10:52 AM.
#343
Posted 04 July 2015 - 05:00 PM
did you get the 3" back box with one of the outlets blocked to reduce DBs ?
is that one of the supersiezed back boxes like mine ?
good idea to get a wideband in while you are there ??
Edited by CHILL Gone DUTCH, 04 July 2015 - 05:01 PM.
#344
Posted 04 July 2015 - 07:34 PM
Jusrt a bog-standard 3" exhaust. I'm hoping I won't need a wideband. Peter's maps are pretty accurate, so should be within the capability of the normal lambda sensors.
noise from the exhaust is something i'll pay close attention to. With the enclosed air filter I should be okay, however we'll see.
Need to source an engine crane now.
#345
Posted 04 July 2015 - 07:41 PM
#346
Posted 04 July 2015 - 07:44 PM
#347
Posted 04 July 2015 - 07:51 PM
I'm not convinced. a narrowband will tell the car if it's running rich or lean. the ECU will then modify. The problem with narrowband is that they don't know how far off stoicometric it is. This leads to a sawtooth style adjustment where it could overshoot and slowly narrow in on the value. As long as i don't run for too long at either extreme I shouldn't have a problem. after all, once i've mapped it, the wideband is just extra cost which isn't bringing any value.
#348
Posted 04 July 2015 - 07:52 PM
now if I end up cutting melted catalyst out of my exhaust, i'll be willing to say I was wrong
#349
Posted 04 July 2015 - 07:56 PM
#350
Posted 04 July 2015 - 07:58 PM
Well the failure of the old one had nothing to do with mapping. It was fretting of the valve keeper.
In reality, the only difference between mapping at above 250 bhp verses lower is the potential of the extreme conditions causing damage to the engine. As long as i avoid running under these conditions for a prolonged time, i'll be fine.
HOWEVER. This car will need an MOT right away, that might be a good reason to get a wideband, as i'll need to get it close to passing emissions pretty quickly...
hmm.
Is there any way to entirely replace pre-cat narrowband with a wideband?
Edited by fezzasus, 04 July 2015 - 08:01 PM.
#351
Posted 04 July 2015 - 07:59 PM
#352
Posted 04 July 2015 - 08:03 PM
I know when I'm fighting a losing battle Good luck
i see your point Chris, my resistance purely comes from the modifications needed to fit the wideband purely for the sake of mapping. I'm really going to try to keep the car in one state of tune once this is all done, so it's hard to justify fitting it for mapping reasons.
#353
Posted 04 July 2015 - 08:08 PM
on a similar subject, I need to give serious consideration over what power i'd actually like out of this thing, as currently i've got VXR injectors which will max out at around 280 bhp, and the original fuel pump, which will probably drop off at the same point.
#354
Posted 04 July 2015 - 08:15 PM
#355
Posted 04 July 2015 - 08:22 PM
It's a shame you fixed the air filter problem, I would have liked to have known if the exhaust or charger were the limiting factor in power output.
My dilemma is this; i would prefer reliable power rather than maximum power, but it would be a shame not to maximise the potential of the engine if it's a simple change. for example, i wouldn't want to be limited by the injectors. It's hard to second guess what the limit of the engine is without setting it all up, but I don't want to do this in stages because it becomes a never ending project.
#356
Posted 04 July 2015 - 08:51 PM
#357
Posted 04 July 2015 - 08:53 PM
#358
Posted 04 July 2015 - 09:22 PM
Problem with running the M62 at that speed is the bearings. They're not rated for it. I won't be going less than my 2.9 pulley.
As for the engine, we'll see. neoBros are selling new ones for £500 now, almost worth taking a punt, right?
#359
Posted 14 August 2015 - 05:03 PM
Work is happening...
Last weekend I changed the subframe shims. Duralac, new shims, new bolts, all back together
Cleaned up the subframe. Wasn't entirely happy with the silver POR15, it was lifting at the edges of the subframe, so knocked it all off and applied Bilt Hamber hydrate 80. Will prime and spray silver
Confirmed the Tullett manifold and cat section fit the 2bular backbox.
This weekend I will be mainly fitting a new bathroom, while waiting for my new dipstick and pipe joining sections to turn up. Exhaust mounts and Corsa radiator S bend (hopefully to relocate the gearbox side water pipe around the saab oil cooler) already here.
#360
Posted 14 March 2016 - 08:42 AM
Progress.
Also found this hiding in the inlet manifold.
