Project 'i Want To Go To Work Today'
488 replies to this topic
#361 The Batman
Posted 14 March 2016 - 08:45 AM
Nice!!!
#362 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 14 March 2016 - 01:46 PM
What Vibra engine mounts did you go for Tom? Fast road or comp?
#363 Exmantaa
Posted 14 March 2016 - 02:23 PM
How is the experience in the UK with the 3" Tullett manifold and downpipe?
Here in NL we have one Speedster (2.2 Harrop track) with a 3" system, and besides the noise issues he already had to reweld his cracked downpipe section twice....
The orientation of that 3" flexi joint is probably not doing much to absorb engine motions and stresses the system. :glare:
#364 techieboy
Posted 14 March 2016 - 02:48 PM
Had to get the end of my flexi welded up as it had cracked, 30 minutes before setting off to Zandvoort last year. Guess it's over 4 years old now but I've never used the first mounting bracket on their advice, after it pulled a chunk out of the pipework on Lee's car on the way back from Le Mans 4 or 5 years back.
#365 fezzasus
Posted 14 March 2016 - 04:13 PM
That's something to look forward to then.
I'm using fast road mounts. I wanted a more durable mount (and liked the improvement I felt from adding the poly inserts to the front and rear) rather than something that felt solidly linked to the chassis.
I'll report back in a few weeks. Needs a service and repairs to the rear clam before it goes back on the road.
#366 fezzasus
Posted 06 June 2016 - 07:23 AM
Car is alive!
Idle is pretty lumpy but should be able to control that a bit by increasing idle speed.
Charge cooling system still needs plugging in, other than that I just need an MOT.
#367 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 06 June 2016 - 10:32 AM
Marvellous. Sent from my iPhone using Tapatalk
#368 Stevie Dubyah
Stevie Dubyah
  • 1,534 posts
  • Interests:Invasive Operations
Posted 06 June 2016 - 12:03 PM
I love the way this thread evolved from:
"Hello my name is Tom. I'm going to document how to make the VX a bit easier to live with. First, I changed the windscreen wiper, then I demisted the lights...."
to
"...supercharged, 3 inch exhaust and painting it purple..."
:D
#369 siztenboots
Posted 06 June 2016 - 12:07 PM
I got Cheesman to supply and fit a much longer flexi section.
#370 fezzasus
Posted 06 June 2016 - 12:17 PM
to
:D
I also have no desire to drive it to work...
#371 fezzasus
Posted 05 July 2016 - 09:21 AM
Insured from the 11th...
#372 fezzasus
Posted 05 July 2016 - 09:45 AM
Chargecooler pump hard mounted:
Wasn't particularly happy with to leave the charge cooler pump hanging off pipework, especially the larger flow Bosch unit. Chassis rails have been drilled and fitted with aluminium rivnuts (key to prevent corrosion), rubber isolation mounts separate the bracket from the chassis.
#373 CHILL Gone DUTCH
Posted 05 July 2016 - 10:22 AM
Nice work What's all the white stuff I. The pic Did someone get over excited 🤐
#374 fezzasus
Posted 05 July 2016 - 11:41 AM
Exhaust heat shielding re purposed. Aluminium spacers should prevent too much heat soak into the subframe, while nylon washers limit any galvanic corrosion between the spacer and subframe. The rest of the shielding has been cut away so exhaust access is easier.
Edited by fezzasus, 05 July 2016 - 11:42 AM.
#375 fezzasus
Posted 05 July 2016 - 11:43 AM
Nice work
That'll be the clam repairs.
Not perfect, but not bad for a rattle can.
#376 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 05 July 2016 - 11:04 PM
Nnnnnnnnice
#377 fezzasus
Posted 10 July 2016 - 09:11 PM
Fecking car. MOT booked for tomorrow and won't start, I've got the relays in rice and battery in charge. Also going to inspect the wiring behind the relay mounts, hopefully one of those will be the cure. Also need to make the washer fluid spray and locate the boot catch.
#378 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 10 July 2016 - 10:10 PM
Check and clean TB connection also.
#379 gaffer1986
gaffer1986
  • 4,408 posts
Posted 10 July 2016 - 10:11 PM
[quote data-cid='1150624' name='fezzasus' timestamp='1298813020' post='1150624']Introduction
VW relay - Part code "357-955-531" or typically with a number 99 printed on the top. Approx £11 from ebay. Allows programable interval wiping by lifting the stalk onto interval, bringing it back down after the wipe, then back up and keeping it on interval. The gap between the two wipes is now the interval. Again, really recommended for day to day driving - reduces the number of distractions and a cheap mod. The relay is located at the top of the passenger footwell and can be identified [only two there] by feeling for a click while the wipers are set to interval. A flat bladed screw driver [with keys out of the ignition!] helps to remove it.
Just found this thread, this sounds really handy, I'll put it on my list.
#380 fezzasus
Posted 12 July 2016 - 07:24 AM
Running on borrowed relays. Mine are a mixture of missing or not working.
However it failed it's MOT as it needed a front numberplate (couldn't find it, but I thought it would be worth going for the MOT as the retest is simple) and the engine couldn't maintain temperature - essentially I ran out of time to bleed the system properly.
Should all be addressed by the retest on Saturday.
