Project 'i Want To Go To Work Today'
488 replies to this topic
#421 fezzasus
Posted 13 August 2016 - 01:16 PM
I see, looks like something you find in a washing machine. :)
Or a 6.0 L V8 GM truck
#422 gaffer1986
gaffer1986
  • 4,408 posts
Posted 13 August 2016 - 01:23 PM
As you can probably tell from some of my posts. I really don't know what I'm talking about. Although I did fix an oven the other day :)
#423 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 13 August 2016 - 03:39 PM
Only 'some' of your posts?..............hmm 😂😂😂
#424 smiley
Posted 13 August 2016 - 03:44 PM
Keep 'm coming gaffer. We love your posts.
(Well, not the oil consumptiom thread flood, but the rest)
#425 gaffer1986
gaffer1986
  • 4,408 posts
Posted 13 August 2016 - 03:52 PM
I thought the oil consumption poll was a good idea. Glad to hear you enjoy my ramblings. ;)
#426 fezzasus
Posted 19 August 2016 - 07:38 PM
PCV system now working.
Slightly better view.
Diagram:
It's not pretty by any means, but it'll work. I'm going to get some nylon braiding to put over the PCV hose to make it look less bodgetastic
#427 smiley
Posted 19 August 2016 - 07:58 PM
Good work.
(though not actually the pcv, as that's in your engine, but the rocker cover breather)
#428 fezzasus
Posted 19 August 2016 - 08:03 PM
Good work. (though not actually the pcv, as that's in your engine, but the rocker cover breather)
Yeah, that was a pretty quick sketch. Technically the entire system is the pcv, but you're right, I've labeled the rocker vent wrong
#429 fezzasus
Posted 23 August 2016 - 08:51 PM
Fuel system progress. Not happy with the crap Motorsport fuel filters, they are too small or too corse filtration.
Step up Bosch filter with an6 adaptors
#430 fezzasus
Posted 26 August 2016 - 07:10 AM
I'll be taking a dremel to my fuel tank access hatch soon to fit all of the above. There's been pretty heated discussion over the impact on the  structural integrity. Firstly, it's minimal as anyone with a hint of engineering awareness should know that the strength of a structure is carried on the edge rather than the face. Secondly, I've found that Lotus enlarge the fuel tank access hatch from the factory for the later cars (photo is from an Exige V6)
#431 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 August 2016 - 09:14 AM
I like your handbrake gaiter and surround.
#432 techieboy
Posted 26 August 2016 - 09:20 AM
#433 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 August 2016 - 09:24 AM
I thought it looked lotus like, the sills look different.
#434 fezzasus
Posted 26 August 2016 - 09:40 AM
A mere £180 if you want it: https://www.deroure....&SMO=0&ST=&SC=0 (items 18 and 24)
#435 gaffer1986
gaffer1986
  • 4,408 posts
Posted 26 August 2016 - 12:06 PM
Stuff that!
#436 fezzasus
Posted 26 August 2016 - 12:09 PM
Stuff that!
My thoughts exactly. I could just about tolerate £58 for the leather gaiter, however £120 for the bezel is pretty shocking.
#437 fezzasus
Posted 17 September 2016 - 09:09 AM
Fuel system
Pump:
DW65a - direct replacement for the OEM pump. Same filter size, same attachment, no need to solder any wires. Turbine impeller so should be much quieter than the Walbro 255
Flow chart:
Filter
Bosch unit with AN6 adaptors. Can retain original installation location.
Pipes
Replaced with stainless steel overbraided PTFE lines. Would strongly recommend use of PTFE rather than rubber as PTFE won't degrade.
PTFE lines means it's almost impossible to implement with JGs layout.
I oped for 90 degree quick fit connectors as shown here;
and done;
#438 Arno
Arno
  • 1,238 posts
Posted 17 September 2016 - 10:01 AM
Yup.. And they won't 'sweat' fuel so you won't get that constant slight background whiff of petrol as is common with rubber hoses.
#439 fezzasus
Posted 20 September 2016 - 05:03 PM
Started making my own headlights (it's only fair that I get a pair). Silver and CF;
#440 Raptor
Raptor
  • 942 posts
Posted 20 September 2016 - 05:15 PM
Very nice. I can only hope I manage to get a set in future.
23 user(s) are reading this topic
0 members, 23 guests, 0 anonymous users
