perfect for le mans though
Project 'i Want To Go To Work Today'
#481
Posted 11 June 2017 - 08:42 PM
#482
Posted 11 June 2017 - 09:45 PM
Edited by gaffer1986, 11 June 2017 - 09:45 PM.
#483
Posted 12 June 2017 - 12:10 AM
I thought NA/SC didn't have crank sensor and used compression sensing something or other? Is this a Saab block thing? Sent from my SM-G920F using TapatalkAre you running an external crank sensor? I am, and I had initial misfire issues. One of the things I changed was the crank sensor (so no idea if it was that), but I also added a small washer to space the sensor back from the mounting position, as the original was marked with the new timing wheel. Works fine now.
Thanks both, seems like the crank sensor was worth changing. I didn't see any marking of the sensor from the external crank trigger wheel, but read a lot about crank sensors (particularly GM ones) developing faults when hot. Fingers crossed I won't have to worry about this again.Your issues sound similar to when my crank sensor plays up.
#484
Posted 12 June 2017 - 12:18 AM
all na's have a crank sensor
#485
Posted 12 June 2017 - 12:34 AM
#486
Posted 12 June 2017 - 08:24 AM
Cam position can be resolved from crank sensor (assumption is that the engine is timed correctly), only start to need a cam sensor with VVT (but that too can be mapped against crank position and throttle position).
#487
Posted 12 June 2017 - 09:40 AM
Ahh.. prob the cam sensor it doesn't have then
Correct. The Z22SE coil pack generates the cam position sensor signal back to the ECU from the compression/ignition sense logic built into it.
It has no actual cam sensor on the engine, but the ECU can still complain about not getting a cam signal (usually a coil pack going bad..)
#488
Posted 08 July 2017 - 07:45 PM
Insurance renewed with A-plan, yielding a massive £130 saving over the renewal rate provided by Henderson Taylor. All mods declared with commuting and NCB protection.
#489
Posted 09 July 2017 - 03:13 PM
