some Z20LET injectors which I already have, but I don't like the idea of running at 98 % duty cycle.
Nick is flogging his surplus VXR injectors at the moment.
Posted 17 July 2013 - 10:27 AM
Posted 17 July 2013 - 10:41 AM
and I was very tempted until I nabbed a set of four new VXR injectors on ebay for the same price.
Posted 17 July 2013 - 10:42 AM
What pulley you onI've got everything bar a 90 degree elbow to mount the CC pump and some VXR injectors - both of which should be in the post, if the worst happens I can have a slightly more messy CC pump install without the elbow and use some Z20LET injectors which I already have, but I don't like the idea of running at 98 % duty cycle.
3.1", I suspect we will have very similar maps once everything is complete.
Posted 17 July 2013 - 10:45 AM
Posted 17 July 2013 - 10:50 AM
Yes I have,
current set up is:
VXR injectors
3.1" pulley
dual pass mod'ed, pro alloy CC, 15 L/min pump
2.5 " larini backbox (eventually a turbo one whenever JakVX pulls his finger out and sends me a U bend), no pre-cat, standard manifold.
75mm dia cone filter
Dutch ECU
However unlike you i'll try to avoid modifying enough to keep standard internals, at least for a bit.
Posted 17 July 2013 - 11:53 AM
Posted 17 July 2013 - 11:59 AM
Not really, I can always lower the rpm limit.
Posted 17 July 2013 - 12:26 PM
Edited by oakmere, 17 July 2013 - 12:27 PM.
Posted 17 July 2013 - 12:43 PM
Agreed, especially as it will mainly be on the road.
Posted 18 July 2013 - 07:22 AM
Done
Charge cooler pipes run
Charge cooler fitted
Charge cooler fans connected
Wiring loom extended, wrapped, injector plugs changed
Header tank fitted
Aux. tensioner replaced
Fuel breather relocated
ECU flashed with base map
Rear clam sprayed
VXR injectors ordered
Fit 100 A alternator, inlet manifold, supercharger
Fit coolant S-bend
re-route fuel lines
Fitted CC pump
Zinc coated subframe
To do
Mount ECU
fit injectors
rewire TB connector
replace rivnuts in subframe
refit rear clam
map
Edited by fezzasus, 18 July 2013 - 07:29 AM.
Posted 18 July 2013 - 07:27 AM
I managed to keep around 250bhp with 3.1 pulley with a rev limit of 6800 But I hadent messed with ignition settings at this point, and only done one learning session.That would be the only other way. With the SC you don't need to rev to 7000 rpm anyway.
Posted 18 July 2013 - 07:29 AM
Posted 18 July 2013 - 07:30 AM
Do you think it's worth running multiple learning sessions without additional changes?
Posted 18 July 2013 - 07:38 AM
Edited by CHILL Gone DUTCH, 18 July 2013 - 07:41 AM.
Posted 18 July 2013 - 07:51 AM
Cheers, very useful going forward. Given the time contraints before The National I will probably just have time for a full learn session and leave the ignition advancement until next week.
Posted 18 July 2013 - 07:53 AM
Posted 18 July 2013 - 07:55 AM
Posted 18 July 2013 - 08:00 AM
Nope, standard lambdas
Posted 18 July 2013 - 08:11 AM
have you tried including the knock measurements in the fuel learn data or have you done a separate knock measurement?
Posted 18 July 2013 - 08:13 AM
