Starting To Climb The Vx Mod Ladder
#181
Posted 16 September 2011 - 11:40 AM
#182
Posted 16 September 2011 - 11:45 AM
If you want the jack through the sill, then by all means jack there
Needs to be about 2-3" closer to the back of the car (that ferking great brace across the middle of the car)
#183
Posted 16 September 2011 - 11:48 AM
Some people on this site are way too sad and full of themselves. TBH theres nothing wrong with his car at all, some of the things like the switches arnt my taste but only because i want no silver/chrome inside the car. I think this car is lovely and i rarely like silver cars. IMO stripes down the middle of the car looks more halfords to me than anything else
Im screwed then. stripes this weekend!
Covering stone chips though, although im gonna be totally chav'd up. Im from Arlow!!
Good work with your car! Id like to see a phot with the mirrors on the car.
#184
Posted 16 September 2011 - 12:08 PM
But the point is ........ it is HIS car and HIS thread.
So if you don't like it stay away from it and start your own thread.
I expect that most people can make up there own mind about this car and do not need a self elected person to give an alternative view point.
Most of us are over the need for that.
But hey. If you want to rain on this guys parade and stop him posting his work, then that is a great way to do it.
But for one I would like to see him keep posting. So good luck to him and I hope that he is still going to post.
Korkey.
#185
Posted 16 September 2011 - 12:09 PM
In that picture is where the original stickers were.
Don't have a photo, but mine's in the same place.
#186
Posted 16 September 2011 - 12:20 PM
If you want the jack through the sill, then by all means jack there![]()
Personally I'd trust Slindy over the guy who's job it is to go stickering the underside of the VX.
Presumably that whole lengthways brace should be reasonably secure no? But yeah where the two meets seems the logical place and where I've been putting my jack, but then again it was Stu who told me to put it there!
#187
Posted 16 September 2011 - 12:33 PM
#188
Posted 16 September 2011 - 12:43 PM
Slindy is spot on ref the jacking point. It is where the cross brace meets the ally sill panel. Jack up both sides there and the car just balances with all four wheels off.
3 times in a year........ You owe me dinner now
#189
Posted 16 September 2011 - 12:44 PM
#190
Posted 16 September 2011 - 01:21 PM
#191
Posted 16 September 2011 - 03:15 PM
You can still see where my original sticker was on my car and in that picture the red ring is right on top. HOWEVER the decal was not fully stuck on then simply loosly balanced for the sake of the photo. They are now positioned with the wording facing the other way and nearer the center line where I have allways jacked the car from in the past having seen photos to the contrary of my oem stickers. It does seem strange the position varies when the placement could be critical though.
#192
Posted 16 September 2011 - 03:23 PM
#193
Posted 16 September 2011 - 03:24 PM
Korkey.
I've not been discouraged at all I simply have not got round to getting anything else done recently and thus have not had any updates to post about.
Since the topic has now been bumped I may as well add some pictures of the windscreen surround I did that I forgot to mention in here -
#194
Posted 16 September 2011 - 03:29 PM
#195
Posted 16 September 2011 - 03:37 PM
Keep modding Oppo till you are happy with it and sod everybody else. Don't take criticism personally, hell I drive Lightning McQueen so used to it now.
Plan to Cliffie, cheers.
I'm actually seriously considering a full custom vinyl project myself. Need to talk to the charity it will be 'promoting' to get there OK then maybe I'll have a word with PP to come up with a design...
#196
Posted 23 October 2011 - 04:41 PM
Front clam off for a general inspection, paint, and clean up of the area and coppergrease of bolts etc. Also enabled me to get the V off in one and fit a stienmetz grille. Thankfully the bolts where all pretty plane sailing so no need for the dremel. Only two seemed to put up a fight but luckilly they where the ones inside the door that simply clamp the clam to the sill so I just undid them enough to slide the sides out. I will be having both a modded V and grille both secured from the front and will alternate between the two as and when the mood takes me.
The wing mirror mod has become a bit more complex than I initially planned. I got hold of a spare set of mirror plinths and have made them into custom mounting plates for the new ones. The aim of this was to retain the use of the original bolt locations and also to keep the same shape against the car as otherwise when removed marks in the paint laquer that I have there would have been on show. It also means they are a simple straight swap replacement if ever I need to go back to the originals.
One finished, one still to do. I got the little rubber boots off of a Vauxhall vans mirror adjustment stalks and they happened to be a perfect fit and hide the join and pivot nicely.
I am not sure yet if I am going to have them black or get them sprayed silver at the same time as some spoiler struts I will be getting done.
Edited by -Dab-of-Oppo-, 23 October 2011 - 04:45 PM.
#197
Posted 24 October 2011 - 08:38 PM
#198
Posted 17 December 2011 - 09:42 AM
#199
Posted 17 December 2011 - 12:54 PM
#200
Posted 17 December 2011 - 02:28 PM
