Posted 08 April 2011 - 01:30 PM
Posted 08 April 2011 - 08:48 PM
Posted 08 April 2011 - 09:22 PM
Posted 10 April 2011 - 09:43 AM
Posted 10 April 2011 - 07:07 PM
Posted 10 April 2011 - 07:22 PM
Posted 10 April 2011 - 07:32 PM
Posted 10 April 2011 - 07:47 PM
What spray glue did you use for the alcantara and where did you buy it from? I have to redo mine as the heat as unstuck a lot of it
Posted 10 April 2011 - 08:18 PM
Posted 10 April 2011 - 08:24 PM
Posted 10 April 2011 - 08:28 PM
Cheers for the info. I think I'm going to use 3M 90 but it seems to be hard to source. I'm hoping some will pop up on ebay soon.
Posted 10 April 2011 - 08:31 PM
Posted 10 April 2011 - 08:43 PM
Please come and do my drinks holder and dash and everything else.
Top work!
Got one of these from Halfrauds for my boost gauge. Cheap as chips but quite solid and could probably be jazzed up a bit with alcathingybobI still need to find a way of mounting the boost gauge. I was thinking of a pillar pod but would not know which to go for to ensure a good fit and I think it may look a bit cramped and odd anyway. I think I am favouring just a simple stand for it on top and in the middle of the screen.
Posted 10 April 2011 - 08:58 PM
Edited by -Dab-of-Oppo-, 10 April 2011 - 08:59 PM.
Posted 10 April 2011 - 09:29 PM
Small hole in the bottom but you can easily drill one in the back if neededThanks for the link, that is exactly what I was just looking at for a few quid less on ebay. Think I might get it from Halfrauds though so I can see it before I buy, I want it with as small a footprint as possible and not too high. I would leave it black to match the vents.
Where do the wires exit through the bottom or back?
Posted 10 April 2011 - 09:43 PM
Use a stapler as well it makes streching the edges over so much easier and takes some load of the glue. I used an effortless electric nail gun that takes them but you could allways just get a hand one for around a fiver. I assume you are upholstering on top of the OEM rubber finish, if so just use those staple locations as guidance points.
Posted 16 April 2011 - 05:53 PM
Posted 16 April 2011 - 05:54 PM
Posted 17 April 2011 - 12:18 AM
Posted 17 April 2011 - 01:45 AM
Also yesterday I had a new Larini exhaust fitted.
