Mira Electric Shower Problems
Posted 19 March 2008 - 08:41 AM
Posted 19 March 2008 - 08:45 AM
Just moved into my new house and the shower is crap!
Turned it on and the pump is very loud, it's also not that powerful. It is more powerful and makes a better noise when you put the shower head lower. For example it doesn't sound like it's going to blow up when the shower head is on the shower base, but the higher up it goes the worse it sounds and the less water comes out. Had a shower and after a while the water just reduced to a trickle and stopped whilst the pump sounded like it was running dry and made a hell of a noise.
Turned it off and back on and no water would come out. I eventually ran it with the shower head hanging on the base of the shower and it eventually started running again, but it's still not very powerful at all and makes so much noise. Any ideas??
Also, the colder you set the shower, the slower the water flow, fully cold and it's just a trickle. Fully hot and it's better, but still not acceptable.
Any ideas?
Because its a nasty mix of water and electricity , it would be unwise to advise .
Mira,
Mira service is only a phone call away:
UK Mainland & Northern Ireland: 0870 241 0888
Republic of Ireland: 01 459 1344
Posted 19 March 2008 - 08:52 AM
Posted 19 March 2008 - 05:25 PM
Posted 19 March 2008 - 06:03 PM
Any ideas?
I thought that an electric shower would slow the flow(less) of water to get warm water & speed up the flow(more) for cooler/cold water. Sounds like something is very wrong. New,new house or previously lived in?
Posted 19 March 2008 - 06:23 PM
Posted 20 March 2008 - 07:47 AM
Posted 20 March 2008 - 09:07 AM
Cold water flow from the taps next to the shower is very strong, so the supply is there.
The house is old, probably 1980's I would have said. Shower is newer as it was a seperate WC that has been knocked through into the bathroom and had a shower installed.
Is it a hard water area ? Can you test the flow with the shower head removed, if so, try leaving the shower head in a container of coca cola overnight to disolve the limescale
Posted 20 March 2008 - 09:41 AM
Posted 20 March 2008 - 04:19 PM
Turned it on and the pump is very loud, it’s also not that powerful. It is more powerful and makes a better noise when you put the shower head lower. For example it doesn’t sound like it’s going to blow up when the shower head is on the shower base, but the higher up it goes the worse it sounds and the less water comes out. Had a shower and after a while the water just reduced to a trickle and stopped whilst the pump sounded like it was running dry and made a hell of a noise.
Turned it off and back on and no water would come out. I eventually ran it with the shower head hanging on the base of the shower and it eventually started running again, but it’s still not very powerful at all and makes so much noise. Any ideas??
Any ideas?
Ok.....
If your Shower has a 'pump' then it's very likely a thermostatic mixer (not electric), which requires both cold AND Hot supplies, and these need to be of a constant and equal pressure (not mains fed, but supplied from a tank).
The Cold supply (if done correctly) will be fed from your main storage tank (in the Loft?)... from your description it would seem the problem is with this cold supply, ie it's either blocked/restricted or Air-locked.
There 'Should' (somewhere) be isolation valves for the hot+Cold supplies to the Shower, if you can find these and turn them off, you could then remove the shower valve and check the internal filters on the inlets (if fitted) you could also then run the cold (into a bucket/your bath) which will prove if the restriction is on the Shower valve or it's supply pipe...
Reduction in pressure on raising the shower head is 'usually' an indication of Low head Pressure, however if fitted correctly the pump should overcome this....... thats what they are for.
If the pump is of the 'Twin impeller' type (one side does hot, the other cold) then it's possible the cold side impeller could have failed......... is the Hot pressure Ok?..
Edited by Garry.L, 20 March 2008 - 04:34 PM.
Posted 24 March 2008 - 09:21 AM
Posted 24 March 2008 - 02:17 PM
